ducatipaso.org • View topic - Cheap 907 M1R legs in USA.
It is currently Wed Apr 22, 2026 12:33 pm
 Post subject: Cheap 907 M1R legs in USA.
PostPosted: Thu Dec 22, 2011 4:04 pm
Dont know if they're for 300 or 320 discs.
http://www.ebay.co.uk/itm/310367136169? ... 1438.l2649
Be quick, ends today.
Cheers, Keith
On a 2nd look I think theyre M1B, he says they're 40mm dia and no adjuster visible.
 Post subject: Re: Cheap 907 M1R legs in USA.
PostPosted: Thu Dec 22, 2011 4:14 pm
if it was from a 907ie the caliper mounts would be 40mm distance. These look like 108mm which is for the old P08 calipers. I think these forks are from a 750 Sport (with 280mm discs).
PostPosted: Thu Dec 22, 2011 11:16 pm
Right Gerd, I wrote to the dealer that this could'nt be a 907 fork. Mounting seems to be for P08 Caliper, and there's no rebound-mechanism at the right leg.
PostPosted: Fri Dec 23, 2011 3:46 am
Certainly, looks like 750 Sport legs from what I can tell. Seen several sets of those now. M1B, no adjusters, 40mm. Not worth owning, unless you have a Sport and want to use 16" wheels. Even less relevant without the triples and axle.
PostPosted: Fri Dec 23, 2011 4:33 am
they relisted them as sport legs
