It is currently Fri Nov 14, 2025 6:37 am
[ 3 posts ] |
| Author |
ynot
Post subject: 12V Power Posted: Mon Aug 20, 2012 3:40 pm |
Joined: Sat Sep 04, 2004 12:00 am Posts: 40 Location: Vienna
Hi!
I have mounted a 12V socket on the black metal piece below the dashboard. Were is the best point to connect the wires on the front side of the bike? It does not matter if it is 12 V permanent or not- permanent would be better. Any idea which plug/ cable I can use for that? The wiring diagram did not really help me..
Thanks Gernot
| Top |
Derek
Post subject: Re: 12V Power Posted: Mon Aug 20, 2012 6:18 pm |
| paso grand pooh-bah |
Probably best to tap into the red wire to the regulator. It goes straight back to the battery through the 30A fuse. An inline fuse at a lesser rating of say 10A might be a good idea too. That should be enough to power most accessories and be good for charging the battery too.
| Top |
blazing928
Post subject: Re: 12V Power Posted: Sun Aug 26, 2012 1:11 pm |
Joined: Tue Sep 15, 2009 4:08 am Posts: 222 Location: Melbourne Vic, Australia
I always run a new wire back to the battery, pretty easy to do, add an in line fuse, less chance to affect something else. [EG; my Garmin is hard wired back to the battery]
_________________ Nigel
91 907IE - full restoration 91 907IE Red, Wilbers, Staintune Conti, Corbin, MPL Slipper,Ceramic exhaust Lambretta LI150 S3 87 928S4
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 1 guest |
