It is currently Tue Oct 27, 2026 2:53 pm
[ 6 posts ] |
| Author |
Beandip
Post subject: Changed oil on 907ie, now won't start. Posted: Sat Apr 19, 2014 6:16 pm |
Joined: Sat Apr 19, 2014 4:30 pm Posts: 3 Location: USA
I had this problem before, I just can't remember what I did to correct the problem. I have 5 bikes, so oil changes can have a time period between them. I pulled all the body work off, drained the oil and left the drain plug out for several days before changing filter and pouring in fresh oil. Went to crank last night, got two pops out of the silencers and that's it. Simply will not fire. Additional note, took this bike on a 250 mile ride last weekend. No issues. Thx.
| Top |
Post subject: Re: Changed oil on 907ie, now won't start. Posted: Sat Apr 19, 2014 9:34 pm |
| paso grand pooh-bah |
| Top |
Beandip
Post subject: Re: Changed oil on 907ie, now won't start. Posted: Sun Apr 20, 2014 3:15 am |
It's all plugged up, that's not it. When I remember the cause of this at 3 am I will post. Thx.
| Top |
900streetfighter
Post subject: Re: Changed oil on 907ie, now won't start. Posted: Sun Apr 20, 2014 4:39 pm |
Joined: Wed Oct 27, 2010 5:52 pm Posts: 364 Location: Essex UK
Is fuel pump priming? off switch on rh bar? check for spark, maybe a connection got knocked.
| Top |
nickta
Post subject: Re: Changed oil on 907ie, now won't start. Posted: Mon Apr 21, 2014 9:24 am |
Joined: Tue Jul 24, 2012 8:54 am Posts: 287 Location: Cairns, Queensland, Australia
Try the old "forgot to plug the fuel pump back in" trick. Its the 4 pin plug/socket below the back of the tank. Easy to miss/forget. You wont have any fuel registering on the gauge either (assuming there is fuel in the tank).
Cheers.
Nick.
| Top |
Beandip
Post subject: Re: Changed oil on 907ie, now won't start. Posted: Mon Apr 21, 2014 6:29 pm |
Discovered I wasn't getting any spark. The only thing I bumped was the off run switch on the right handlebar. This also controls the fuel pump and it was priming, so I didn't mess with it much. I found that if I removed the fuse from one of the power relays I would get spark as the electric field in the coils collapsed, so I checked out the ignition sensor. It checked out good on the bench, so back in it went. Before hooking it back up I hit the connection point with a little WD40 along with a couple others. After that it fired right up which concerns me. Just a little too easy.
| Top |
[ 6 posts ] |
Users browsing this forum: No registered users and 20 guests |
