It is currently Tue Oct 27, 2026 1:36 pm
 Post subject: Swingarm
PostPosted: Fri Oct 24, 2014 11:32 am
Hello
Has anyone tried if the swing arm 906 fits in the 907ie. ??
The problem could be the 17-inch tires.
regards
Uwe
 Post subject: Re: Swingarm
PostPosted: Fri Oct 24, 2014 12:22 pm
the front part of the swingarm is identical so it will fit engine and frame but it`s a little shorter, it has a different width, a different axle diameter, the pin that holds the rear caliper bracket is in a different position so the bracket of the 907ie won`t fit etc.
