It is currently Wed Oct 28, 2026 3:12 pm
[ 3 posts ] |
| Author |
docbob
Post subject: 907i.e. tach problems Posted: Sun Nov 02, 2014 3:53 pm |
Joined: Tue Oct 20, 2009 7:22 pm Posts: 13 Location: Boulder, CO
My tach suddenly stopped working. Occasionally dribbles up to 1000 rpm at best. Does anyone know any simple diagnostics for one of these? if it's kaput, I'm looking for one--will an earlier 906 or 750 Paso tach work?
Thanks,
Bob
| Top |
ducinthebay
Post subject: Re: 907i.e. tach problems Posted: Sun Nov 02, 2014 5:06 pm |
| paso grand pooh-bah |
Start with the cable. Like the speedo, its a spinning cable inside housing. If they get a bit dry, they will seize up and twist off. There is a ferrel on the top side to help support the inner cable and be a bearing. Like the speedo cable and speedo drive, they are often neglected an need some lube from time to time.
I just put one on my bike and the inner cable was really dry. I used some motor oil on it.
| Top |
h1a
Post subject: Re: 907i.e. tach problems Posted: Sun Nov 02, 2014 10:16 pm |
Joined: Tue Feb 14, 2006 12:00 am Posts: 75 Location: Oslo Norway
Hi, had similar symptoms on mine, turned out the gears in the head was worn out, parts 13 in this pic:
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 10 guests |
