ducatipaso.org • View topic - Stebel Air Horn mounted
It is currently Tue Oct 27, 2026 3:49 pm
 Post subject: Stebel Air Horn mounted
PostPosted: Tue Nov 11, 2014 9:21 pm
found a place to put the Stebel compact air horn on the 907.
Right behind the headlight, using the stock mounting tab. I used a long 6mm bolt, and used a piece of clear vinyl tubing around it for a spacer, and put a locknut underneath the existing nut welded to the frame. I bent back the mounting tab a bit so that the horn clears the headlight shell. Fits tight, but fits. Still has 6" to the fender, so it shouldn't hit the fender under full travel.
Of course, the sound is just lovely. Glad I could find a place to put it on this bike.
 Post subject: Re: Stebel Air Horn mounted
PostPosted: Tue Nov 11, 2014 10:23 pm
I actually fit my pump above the headlight and the horns in the original place, But I am thinking of moving the pump to the relay plate since I have moved the regulator to under the seat
