ducatipaso.org • View topic - Fork Height in the triples on 907?
It is currently Tue Oct 27, 2026 1:43 pm
 Post subject: Fork Height in the triples on 907?
PostPosted: Tue Dec 16, 2014 1:34 am
Gents,
I'm putting the front end back together, all looks good so far. New oil in forks, greased the steering bearings.
How high do you run your forks in the triple clamps? Mine were about 3mm above the top triple when I took it apart. In general, I like a bit quicker steering. Can I get away with 10mm of fork showing above the top triple? The limit is hitting of parts with the front wheel/fender, such as the radiator and fairing.
I have bar risers, so I can slide the forks up in the clamps quite a bit. All else is stock.
I searched the forums, but didn't find anything definitive.
Cheers, Phil.
 Post subject: Re: Fork Height in the triples on 907?
PostPosted: Tue Dec 16, 2014 2:14 am
ducinthebay:
I set my bike up using the tried and true method of ride height, suspension sag, and so on. See below:
http://www.suspensionshop.org/tech_suspension_setup.php
As far as my front forks, after the ride height, sag, etc. was set, they are pretty much all the way up to where they stop against the stock bar mounts.
I'm about 6'-0" tall, 225 lbs.
du907
PostPosted: Tue Dec 16, 2014 7:10 pm
Thanks for the response. I got the suspension set up procedure already, but was looking for the limit of how high I can run the forks above the triples before the front wheel starts bumping into the bike at full travel.
PostPosted: Tue Dec 16, 2014 7:22 pm
PostPosted: Tue Dec 16, 2014 10:12 pm
PostPosted: Mon Dec 22, 2014 1:37 am
A 907 I saw who was saidt to be in original mode had 10mm over triple.
I have the same w original springs and 3mm washers f additional
spring preload.Works well f me, 92\191.
PostPosted: Mon Dec 22, 2014 2:30 am
Thanks, that's where I will set them for now.
