It is currently Sat Jan 10, 2026 9:51 pm
| Author |
JoKing
Post subject: Re: Guide bushings on 907 ie M1R forks Posted: Fri Apr 13, 2012 6:36 pm |
Joined: Mon Jun 20, 2005 12:00 am Posts: 362 Location: Northern Germany / Kiel
_________________ 92` Ducati 907 i.e. - ST3-Conversion --> Burned down with my barn 78` Ducati 900 SS - Bevel --> Sved her by risking my life 90` Cagiva Freccia C12R - Paso`s smaller sister --> Burned down with my barn 86` Ducati 750 Paso 96` Cagiva 750 AC Elefant
| Top |
Post subject: Re: Guide bushings on 907 ie M1R forks Posted: Thu Sep 03, 2015 11:58 am |
| paso grand pooh-bah |
does someone have the dimensions of the upper bushes? The part number of the P750/906 bushes is different and I wonder why. I would assume the parts would be the same. In case they are another option for the bushes would be the Guzzi part number 30530520 used on:
MG 1100 Sport (carbed) , 1994 - 1996 MG 1100 Sport carbed , 1994 - 1996 MG Daytona , 1991 - 1995 MG Quota , 1992 - 1997 MG Quota ES `99-`01 , 1999 - 2001
| Top |
ducbertus
Post subject: Re: Guide bushings on 907 ie M1R forks Posted: Thu Sep 03, 2015 8:35 pm |
Joined: Sun Jan 07, 2007 12:00 am Posts: 531 Location: holland
Hi Gert,
I've a set of new BMW K1100 bushes laying around, waiting to be mounted. saterday I'll measure them up for you. they ment to go in a M1R of a '91 907
Bertus
| Top |
ducbertus
Post subject: Re: Guide bushings on 907 ie M1R forks Posted: Sat Sep 19, 2015 11:31 am |
Hi, finally have the bushes at hand. these are ment for a Beemer K1100, but should fit the M1R fork from a 907 as well upper bushing:#nr: 31 42 2 310 347 Ø outside ± 44.55 mm; height: 19.8 mm lower bushing: #nr: 31 42 2 310 346 Ø outside ± 41.60 mm: height: 15 mm
regards, Bertus
| Top |
Users browsing this forum: No registered users and 3 guests |
