ducatipaso.org • View topic - 08 848 stator to 907
It is currently Wed Nov 12, 2025 12:04 pm
 Post subject: 08 848 stator to 907
PostPosted: Fri Sep 09, 2016 1:15 am
Does anyone know if a 08 848 stator will work on a 91 907ie?
Thank You
 Post subject: Re: 08 848 stator to 907
PostPosted: Fri Sep 09, 2016 9:20 am
It can't be fitted. The 907 is single phase with the rotor turning inside the stator. The 848 is 3-phase and the rotor turns around the outside of the stator. The crank is different to take later rotor which is part of the flywheel assembly and the outer casing is different to house the 3-phase stator. There are so many changes that you'd need to swap the entire lower half of the engine - crank, crankcases, alternator cover and probably an awful lot more, if it could be done at all.
