It is currently Mon Sep 29, 2025 7:53 pm
[ 5 posts ] |
Author |
unclezip
Post subject: Syncing TBs... Posted: Sun Apr 30, 2017 2:22 am |
Joined: Sun Aug 14, 2016 11:06 pm Posts: 47 Location: Coastal Maine, USA
Rode about a hundred miles today..new gas.....most enjoyable......runs good although there is an occasional pop...lean miss or ?.....mostly no load, mid revs.....so I'm going to ck the tps and sync.......any advise before I dive in?..I mean other than the usual procedure.....I did a search here and only got one hit..no real info....had a similar issue on my Guzzi..setting the TBs cured it...
Every place I stopped..someone had a comment...one guy saw me in Walmart, I was carrying my helmet....he asked "is that your Ducati out there?"...I say Yes..he says "man that's a sweet ride.." . I love this motorcycle...
_________________ 92 907 i.e. 2016 F6B 2001 MG Jackal 1980 XS Eleven/1960 Watsonian sidecar 1974 Norton Commando/Factory Production Race
Top |
Post subject: Re: Syncing TBs... Posted: Sun Apr 30, 2017 2:52 am |
paso grand pooh-bah |
Full procedure can be found in the 907ie documents folder
Top |
Derek
Post subject: Re: Syncing TBs... Posted: Sun Apr 30, 2017 10:01 am |
Brad Black has all the info you need here Give the article a thorough read before you start so you fully understand the procedure.
Top |
unclezip
Post subject: Re: Syncing TBs... Posted: Sun Apr 30, 2017 5:24 pm |
Thanks..good reads....
Top |
unclezip
Post subject: Re: Syncing TBs... Posted: Sun Aug 20, 2017 4:36 pm |
Update....this bike has been on back burner for a while..although I've ridden a few times.... Guzzi trans seals...big job...other life events to take care of.... Anyway, had the time and quiet today to pull her apart, clean up the TBs, set the TPS (which was out of spec), balance and set the CO as per Brad Black....also repaired the infamous voltage regulator connection... Wow...what a difference!!..... Sweeeeet!!, Thanks for the direction and ride happy!......
Top |
[ 5 posts ] |
Users browsing this forum: No registered users and 27 guests |
