It is currently Mon Jul 13, 2026 11:07 pm
[ 9 posts ] |
| Author |
gpsheehan
Post subject: 907 rear turn signal post Posted: Sat May 05, 2018 6:24 pm |
Joined: Wed Feb 20, 2008 1:14 pm Posts: 30 Location: Flemigton, NJ
Hi Was wondering if anyone has a suggestion on what to use to replace the rear turn signal post. The post is the flexible rubber part that the actual turn signal body connects to on US bikes. Both of mine have begun to fall apart and would like to replace them with something newer. Any suggestions? Thanks Gary
| Top |
a330us
Post subject: Re: 907 rear turn signal post Posted: Wed May 16, 2018 3:32 am |
Joined: Mon Dec 02, 2013 2:31 pm Posts: 154 Location: winston salem, nc usa
Yes, found some by accident that look almost identical to stock ones and fit perfectly when buying some from UK for my 95 triumphs. I had to replaced some broken ones a few months ago with what appeared to be perfect stock ones and next morning they had broken and were dangling from, I guess, their own weight. I think buying stock ones at this point in time is a waste of money. Mine came from Sprint manufacturing and they make a few lengths depending on what model triumph you're buying for. I just picked the longest ones I could find for the rear and although still maybe 3/4 inch shorter than stock, a good thing for looks I think, I don't think you'll break these. They're almost like a hard plastic and stock washers and nuts fit also. they have the same triangular end that fits the housing just like the stock ones. Hope that helps, Arch.
| Top |
gpsheehan
Post subject: Re: 907 rear turn signal post Posted: Wed May 16, 2018 8:40 am |
Thanks guys.
Arch Did you see them on the Sprint website? I scanned the site but didn't see any reference to rear turn signals. Gary
| Top |
a330us
Post subject: Re: 907 rear turn signal post Posted: Wed May 16, 2018 2:51 pm |
Hi Gary, Yes, that's where I got mine from, being English you might use the word indicators instead of TS. I'm sure they are in there somewhere. They make quality products for the later Triumphs and they are so alike to the Paso's that they must have come from the same source when new. Arch.
| Top |
a330us
Post subject: Re: 907 rear turn signal post Posted: Wed May 16, 2018 3:13 pm |
Just went to the Sprint website and used indicator stalks in the search field and they popped right up. I bought the sprint sport front stalks since they were the longest ones at the body being 85mm and 105mm from the end of the threaded portion. Hope that helps. Arch.
| Top |
a330us
Post subject: Re: 907 rear turn signal post Posted: Wed May 16, 2018 7:46 pm |
I knew if I waited long enough that G would bail me out on the website that I haven't figured out yet!! :-) Arch.
| Top |
gpsheehan
Post subject: Re: 907 rear turn signal post Posted: Thu May 17, 2018 10:36 am |
Guys Thank you for the info, Between the ebay pair and the Sprint indicators will be able to get back on the road soon. Gary
| Top |
[ 9 posts ] |
Users browsing this forum: No registered users and 5 guests |
