ducatipaso.org • View topic - Gearbox output shaft oil seal
It is currently Thu Nov 13, 2025 7:32 pm
 Post subject: Gearbox output shaft oil seal
PostPosted: Tue May 22, 2018 2:33 pm
The output shaft oil seal on my 907ie appears to be leaking. Does anyone know the size so that I can have one to hand before starting work to change it?
 Post subject: Re: Gearbox output shaft oil seal
PostPosted: Wed May 23, 2018 10:44 am
I don't know the size but Stein Dinse is always a good source for such info. It's part 8, right?
https://www.stein-dinse.biz/eliste/elis ... 544g&lg=de
That would be
https://www.stein-dinse.biz/images/prod ... 832552.jpg
Corteco 25-52-7 BASL DRW (or is that 62?!)
BA = rubber shrouded
SL = second lip (against dust & dirt)
DRW = double sense of rotation
The last seems logical. I'm stunned to learn that there's actually a RD-RH and RS-LH spec which are for right or left hand rotation.
PostPosted: Wed May 23, 2018 1:01 pm
Yes, I'd spotted that image and assuming that it's the actual seal and not just a generic image then it will be 25mm ID x 52mm OD x 7mm Width. I guess I'll just have to pull the sprocket off and have a look. I was thinking of replacing it with a Viton R23 (double lip) seal.
PostPosted: Sat Jul 14, 2018 2:53 pm
Hi Derek
Can you let us know any tricks/tips if you get there before me. I have just ordered one.
Cheers Tom.
PostPosted: Sun Jul 15, 2018 8:20 am
Sorry Tom, I haven't done anything about it yet and will probably leave it until the winter. I don't foresee any problems though - remove the sprocket, screw a self tapping screw into the old seal to provide something to grip on then attach a pair of pliers or similar grip and pull the seal out. I'd apply pvc tape over the fluted part of the shaft to protect the lip when fitting the new seal and oil the seal before fitting. Gently tap it down square with a suitable drift (tube, socket or whatever). Refit the sprocket. Job done.
PostPosted: Thu Jul 19, 2018 10:28 pm
Just done mine Derek and it was as simple as you said.
I ordered the seal, my one error was to order a single lip seal. However it is so easy to change that Im not too worried if it does nt last.
Cheers Tom.
