ducatipaso.org • View topic - Starter solenoid mod
It is currently Tue Oct 27, 2026 8:15 pm
 Post subject: Starter solenoid mod
PostPosted: Wed Mar 28, 2018 6:14 pm
I was getting fed up with the poor connection to the starter solenoid on my 907ie. These are the old style solenoid with the plug in connector that has a habit of falling out. Even with a cable tie round it doesn't always make a connection. The trouble is that the round socket terminals get enlarged and just don't grip the pins in the solenoid properly.
I wanted to fix this once and for all by replacing the solenoid with a spare 1098 one that I have and replace the loom connector with one that matches the inline connector on the solenoid but was unable to find a source for the connector anywhere.
However, since the original solenoid itself was ok but it's connector was source of the problem, I decided to modify it. I soldered wires directly to the pins in the connector and fitted an AMP Superseal connector to the other end, fitting the matching connector to the loom. It's working great now. The white goop is silicon I used to seal the soldered joints.
 Post subject: Re: Starter solenoid mod
PostPosted: Wed Mar 28, 2018 10:01 pm
Ha Ha just done exact same thing with my re wire although I am in no position to test it as have half the loom still stripped.
PostPosted: Thu Mar 29, 2018 8:13 am
PostPosted: Mon Apr 02, 2018 4:00 am
I pushed mine down Queen st for about 2 blocks ( :mad: hot day , gathering audience ) before thinkin' of lookin under the seat :idea: . Paso would have to be the most bastardy bike to try and crash start as you cant really jump on board ( side saddle )when you get the plot rolling
PostPosted: Mon Sep 06, 2021 6:02 am
so with this mod, (Im having the same problem) have you just soldered the wire directly to the terminals or did you solder the original connectors removed from the plastic housing? thanks.
PostPosted: Mon Sep 06, 2021 8:35 pm
I have soldered directly onto the solenoid and then attached a waterproof block connector further along and higher up as for the two wires they are now individually encapsulated at the solenoid with heat shrink.
You can still separate and remove everything as before it just means that annoying little block now will never vibrate off the solenoid.
PostPosted: Mon Sep 06, 2021 9:57 pm
I have had this problem, and this looks like the solution well done!
The Benelliman
1992 907ie
1981 Benelli 900 Sei
1989 Benelli 900 Sei
1976 Benelli 125 Enduro
1981 Benelli 250 2c
1976 Benelli 250 Quattro
