ducatipaso.org • View topic - Fantastic Ride yesterday! Quick clutch question..
It is currently Mon Apr 27, 2026 2:54 pm
 Post subject: Fantastic Ride yesterday! Quick clutch question..
PostPosted: Tue May 30, 2006 4:02 pm
PostPosted: Tue May 30, 2006 5:01 pm
PostPosted: Tue May 30, 2006 5:45 pm
Rogero
1992 "Red" 907 I.E.
PostPosted: Tue May 30, 2006 6:26 pm
PostPosted: Wed May 31, 2006 4:07 am
[quote="Texas907ie"]Thanks Duc750 - I am guessing from your post that there is no adjustment in our hydraulic clutches then and, if anything, I should just bleed the system to ensure there is no air being compressed in it?
The only adjustment I know of is the screw at the base of the hand lever. I've never needed to adjust it but you could see if moving it in or out makes the contact point feel more comfortable.
PostPosted: Wed May 31, 2006 8:26 am
Apart from a specific span adjust on the lever I have never found a way to adjust the span to the bite point on any hydraulic clutches There probbably is a way to do it but whether it would be the "accepted safe method of doing this" is another question. There's always a way to do these sort of things but for me my engineering knowledge (and confidence in my own knowledge) sometimes stops short :D
- Basically I won't F**% it up if I'm not sure I can fix it ! :cool:
