ducatipaso.org • View topic - electrics
It is currently Mon Sep 29, 2025 11:38 pm
 Post subject: electrics
PostPosted: Wed May 31, 2006 5:24 pm
PostPosted: Wed May 31, 2006 6:29 pm
PostPosted: Thu Jun 01, 2006 12:50 pm
PostPosted: Thu Jun 01, 2006 1:23 pm
PostPosted: Thu Jun 01, 2006 5:25 pm
U have SHORTCUT in turn signal circuit !!! Check, what direction burns Your fuse and then its in front or rear... It can be, that, when change bulb, then contact surface of bulb holder goes to connection with earth and then it blows fuse, like happen one time to me in my 907IE. Also can be other way shortcut... Anyway, fuse dont blow, if wires are ok, so You have very simple job to look carefully those wires.... at end You find shortcut! :thumbup:
PostPosted: Fri Jun 02, 2006 1:04 pm
PostPosted: Fri Jun 02, 2006 7:55 pm
PostPosted: Fri Jun 09, 2006 1:30 am
Mark,
Keep that Paso running sweet. It's not often we see 2 out for a ride and I hope to see you out this year for another run in the Catskills...
PostPosted: Tue Jun 13, 2006 12:26 pm
John,
Will do. It's been a busy year, but I'm definitely planning on the catskills group ride next month. And you'll be able to hear her this time... :D
Users browsing this forum: No registered users and 70 guests
