It is currently Mon Sep 29, 2025 9:07 pm
Author |
Message |
richard
Post subject: Re: FARTINESS CURED Posted: Thu Dec 13, 2012 6:13 pm |
Joined: Fri Oct 19, 2012 7:35 pm Posts: 25 Location: CARDIFF
Top |
giocast
Post subject: Re: FARTINESS CURED Posted: Thu Dec 13, 2012 6:55 pm |
Joined: Sat Sep 18, 2010 8:00 pm Posts: 136 Location: UK
Hi Richard Glad you got to the bottom of this problem, I would love to know exactly what your friend did to cure the problem as I wasn't aware there was scope for mixture adjustment (as has been said). I remember that a 'dribbling' injector or one that is malfunctioning can fail to promote good atomisation at low engine speeds and hence 'deliver a weaker charge - is this what was happening?. Manifold air leaks could cause similar effects as well as vacuum always greater at the same kind of engine speeds.
Top |
richard
Post subject: Re: FARTINESS CURED Posted: Sat Dec 22, 2012 5:45 pm |
Hi Giocast We checked the exhaust with a probe and altered the adjuster screws which are on the right hand side of the bike until we got what my friend regarded as an improvement. He expected a certain level on his readout screen and one cylinder was below par. So we made them more equal in terms of the readout. RP
Top |
Derek
Post subject: Re: FARTINESS CURED Posted: Sun Dec 23, 2012 10:05 am |
paso grand pooh-bah |
Joined: Thu Nov 03, 2011 10:13 am Posts: 769 Location: Scotland
Sounds like he adjusted the airbleed screws to achieve the same CO reading for both cylinders.
_________________ 1994 907ie 2017 Supersport 939 2015 Scrambler Classic 1982 Pantah 500SL (now sold)
Top |
richard
Post subject: Re: FARTINESS CURED Posted: Fri Jan 04, 2013 2:40 pm |
Top |
du907
Post subject: Re: FARTINESS CURED Posted: Thu Jan 31, 2013 2:46 am |
Joined: Fri Jul 08, 2005 12:00 am Posts: 336 Location: Winston-Salem, N.C. USA
I agree with above. The screws he adjusted where the air bleed screws.
Just as a reminder, below quote comes from the setup guide that is on this site and the web. Set the IDLE Balance by adjusting the airbleed screws counterclockwise and confirming that the vacuum is identical for both cylinders at idle. You can rev the engine and observe vacuum tracking through the rev range, and then observe idle vacuum restabilising. NOTE Since the airbleeds are designed to iron out any irregularities in the throttle's function, by their nature there is no default setting, unlike the idle screws on a carburettor. If anything the default setting is fully closed. Airbleeds can also be balanced using a 2 channel CO meter. In this case, just adjust the bleeds until both cylinders have the same CO. • Adjust the IDLE Mixture. Finally you get to set the CO Trimmer ! This will affect both cylinders by the same amount, so you need to set the airbleeds first. A typical CO figure for idle is 4% to 6%, but automotive regulations usually specify a CO of under 1% to meet emmissions standards. A V-twin will idle very poorly if the CO is set below 1%, so if you are really bothered try a setting of about 3%. Note that you may need to finesse the airbleeds at this stage.
Top |
Who is online |
Users browsing this forum: No registered users and 35 guests |
