ducatipaso.org • View topic - Pre starting sequence when key is turned on ? Help????
It is currently Sun Sep 28, 2025 9:18 pm
 Post subject: Pre starting sequence when key is turned on ? Help????
PostPosted: Tue May 02, 2006 10:14 pm
PostPosted: Wed May 03, 2006 3:34 am
1992 907ie #1473 Nero SOLD
PostPosted: Wed May 03, 2006 2:34 pm
PostPosted: Wed May 03, 2006 6:57 pm
PostPosted: Wed May 03, 2006 9:35 pm
Nope, Never had the tank off.... As soon as I get the bike trailered back home tonight I'll check that plug and repost..... Damn, hope its not the fuel pump... :eek: !
Thanks Doug!
PostPosted: Thu May 04, 2006 3:11 am
if you find its the fuel pump here is a bosch part number that works perfectly in place of the oem weber pump(i have one going on its third year now)
bosch # 0 580 463 999
google it and usually you can find it at three or four places,i used http://www.rockauto.com and it cost me 171.99 in 2004
doug hunt
PostPosted: Thu May 04, 2006 4:19 pm
907IE relays under front fairing left side in metal plate(looking from FRONT to BACK):
1. Blinkers
2. ECU and ECU sensors
3. Fuel pump, Ignition modules and coils
:thumbup:
PostPosted: Fri May 05, 2006 1:40 am
CRAP! its the pump.... :sad: Have voltage and have now checked the continuity of the third relay and its good.....Bummer....
Doug, Thanks for the info on the part! That helps alot....
Thanks Finn for the help.
Dino
