Pre starting sequence when key is turned on ? Help???? http://ducatipaso.org/forum/viewtopic.php?f=3&t=1047 |
Author: | Dino [ Tue May 02, 2006 10:14 pm ] |
Post subject: | Pre starting sequence when key is turned on ? Help???? |
Author: | Stingray230SX [ Wed May 03, 2006 3:34 am ] |
Post subject: | |
Author: | Dino [ Wed May 03, 2006 2:34 pm ] |
Post subject: | |
Author: | Stingray230SX [ Wed May 03, 2006 6:57 pm ] |
Post subject: | |
Author: | Dino [ Wed May 03, 2006 9:35 pm ] |
Post subject: | |
Nope, Never had the tank off.... As soon as I get the bike trailered back home tonight I'll check that plug and repost..... Damn, hope its not the fuel pump... ![]() Thanks Doug! |
Author: | Stingray230SX [ Thu May 04, 2006 3:11 am ] |
Post subject: | |
if you find its the fuel pump here is a bosch part number that works perfectly in place of the oem weber pump(i have one going on its third year now) bosch # 0 580 463 999 google it and usually you can find it at three or four places,i used http://www.rockauto.com and it cost me 171.99 in 2004 doug hunt |
Author: | Finnpaso [ Thu May 04, 2006 4:19 pm ] |
Post subject: | |
907IE relays under front fairing left side in metal plate(looking from FRONT to BACK): 1. Blinkers 2. ECU and ECU sensors 3. Fuel pump, Ignition modules and coils :thumbup: |
Author: | Dino [ Fri May 05, 2006 1:40 am ] |
Post subject: | |
CRAP! its the pump.... ![]() Doug, Thanks for the info on the part! That helps alot.... Thanks Finn for the help. Dino |
