| electrics http://ducatipaso.org/forum/viewtopic.php?f=3&t=1117 |
| Author: | marringt [ Wed May 31, 2006 5:24 pm ] |
| Post subject: | electrics |
| Author: | pencilbeam [ Wed May 31, 2006 6:29 pm ] |
| Post subject: | |
| Author: | marringt [ Thu Jun 01, 2006 12:50 pm ] |
| Post subject: | |
| Author: | pencilbeam [ Thu Jun 01, 2006 1:23 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Thu Jun 01, 2006 5:25 pm ] |
| Post subject: | |
U have SHORTCUT in turn signal circuit !!! Check, what direction burns Your fuse and then its in front or rear... It can be, that, when change bulb, then contact surface of bulb holder goes to connection with earth and then it blows fuse, like happen one time to me in my 907IE. Also can be other way shortcut... Anyway, fuse dont blow, if wires are ok, so You have very simple job to look carefully those wires.... at end You find shortcut! :thumbup: |
| Author: | marringt [ Fri Jun 02, 2006 1:04 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Fri Jun 02, 2006 7:55 pm ] |
| Post subject: | |
| Author: | jcslocum [ Fri Jun 09, 2006 1:30 am ] |
| Post subject: | |
Mark, Keep that Paso running sweet. It's not often we see 2 out for a ride and I hope to see you out this year for another run in the Catskills... |
| Author: | marringt [ Tue Jun 13, 2006 12:26 pm ] |
| Post subject: | |
John, Will do. It's been a busy year, but I'm definitely planning on the catskills group ride next month. And you'll be able to hear her this time... |
