| Compression Readings http://ducatipaso.org/forum/viewtopic.php?f=3&t=1325 |
| Author: | Timbo [ Wed Sep 20, 2006 11:23 am ] |
| Post subject: | Compression Readings |
| Author: | Finnpaso [ Wed Sep 20, 2006 7:34 pm ] |
| Post subject: | |
When You have checked Your valve clearances???? If they are totally wrong, it can happen that way..... I havent measured compressions in my 907, but its easy job in all car maintaining companies and if they are "low", or another is low, U have problems in valves.... I know, that if valve clearences are NOT correct, then U HAVE such starting problems and normally, when engine gets hot, it goes more worst.... |
| Author: | Timbo [ Thu Sep 21, 2006 9:49 am ] |
| Post subject: | |
| Author: | Finnpaso [ Thu Sep 21, 2006 7:22 pm ] |
| Post subject: | |
| Author: | Timbo [ Thu Sep 21, 2006 11:58 pm ] |
| Post subject: | |
| Author: | jcslocum [ Fri Sep 22, 2006 12:30 am ] |
| Post subject: | |
Timbo, Before tearing it down you can do a simple leak down test to determine exactly where the compressed air is going. Have you done this before? It not much harder than a comression test. If the valves haven't beed adjusted for years/miles this could be the simple cause of low compression. Easier to check valve clearance than tear the top end off. Check out the Ducati Suite for instructions. |
| Author: | Finnpaso [ Fri Sep 22, 2006 7:46 pm ] |
| Post subject: | |
It can be burned exhaust valves, totally wrong valve clearances, bad valve seats, bad valve guides..... But check valve clearances first !!! |
| Author: | Timbo [ Fri Sep 22, 2006 8:13 pm ] |
| Post subject: | |
Thanks for replies I will set to with the feeler gauges ths week-end and let you know what the findings are. Many thanks Timbo :thumbup: 907 ie red 1992 851 Strada red 1992 |
| Author: | Finnpaso [ Sat Sep 23, 2006 8:00 pm ] |
| Post subject: | |
We are waiting.... maybe some very intresting Paso problem again... |
