| Tires, rear brake problem, rear tail light http://ducatipaso.org/forum/viewtopic.php?f=3&t=1412 |
| Author: | Yank907 [ Fri Oct 27, 2006 2:46 am ] |
| Post subject: | Tires, rear brake problem, rear tail light |
| Author: | DesmoDog [ Fri Oct 27, 2006 4:15 am ] |
| Post subject: | |
| Author: | persempre907 [ Fri Oct 27, 2006 9:58 am ] |
| Post subject: | |
| Author: | DesmoDog [ Fri Oct 27, 2006 11:39 am ] |
| Post subject: | |
| Author: | jcslocum [ Fri Oct 27, 2006 12:05 pm ] |
| Post subject: | |
| Author: | Yank907 [ Fri Oct 27, 2006 7:35 pm ] |
| Post subject: | |
Thanks guys, I knew this site was gonna have some good advice I may go wider with the rear but the front I will leave stock. Any thoughts on the rear brake sticking? |
| Author: | Finnpaso [ Fri Oct 27, 2006 8:28 pm ] |
| Post subject: | |
There is ONLY VERY SMALL difference between 170 and 180 rear tires, mostly its only "look of bike". I used earlier 170 and last 4 tires have been 180. Not so "big thing" and surely U can use 180/55 without any problems. Front U should use normal 120 tire. :thumbup: Check that master cylinder in rear brake, that it function, like should. There can be also problem in piston/sylinder: shit inside! |
| Author: | Yank907 [ Sat Oct 28, 2006 7:17 am ] |
| Post subject: | |
| Author: | persempre907 [ Sat Oct 28, 2006 7:30 am ] |
| Post subject: | |
