ducatipaso.org • View topic - New Aftermarket Shock for 907?
It is currently Fri May 01, 2026 10:17 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
 Post subject: New Aftermarket Shock for 907?
PostPosted: Wed Nov 15, 2006 7:07 am
PostPosted: Wed Nov 15, 2006 3:03 pm
-Craig
PostPosted: Wed Nov 15, 2006 6:47 pm
Dug out the info on my Paso750 Rear SHock:
Fox Racing Shock
399-16-000-1
997-15-005A (Ducati Paso 750)
039-08-059-A Spring: [7.000 TLG x 2.250 ID x 350 lbs/in
This is from the invoice direct from Fox, 408.269.9201.
Total cost back in July of 2000 was $609.00
 Post subject: 907 shock
PostPosted: Wed Nov 15, 2006 7:24 pm
Thanks for the data. Is this the same for the 907ie as for your 750 Paso? BTW, the Fox has got to be way cheaper than an Ohlins....
PostPosted: Wed Nov 15, 2006 7:59 pm
now on eBay you can see an overhaul kit for the 906/907 shock.
If you're interested...
http://cgi.ebay.com/Ducati-PASO-906-Mar ... dZViewItem
 Post subject: paso shock rebuild?
PostPosted: Wed Nov 15, 2006 9:24 pm
 Post subject: aftermarket shock
PostPosted: Wed Nov 15, 2006 10:29 pm
PostPosted: Wed Nov 15, 2006 11:35 pm
Spend a little time in the archives and you will see i spent about year and a half trying to find Ohlins for my 907. Ohlins built shocks for the 750 to Ducati specs. These were only available thru Ducati network. They never built and will not custom build for 907. I know, i tried.
Best option in my opinion is Penske 8981 series which they will valve and spring to your weight and riding style.
If you are interested in a good stock shock, i sold my 907 a few weeks ago and gave new owner the shock which has 6000 miles total on it and needs only nitrogen recharge[any decent dirt bike shop]. Cliff says will put on Ebay eventually.
PostPosted: Thu Nov 16, 2006 12:59 am
haven given this much thought really, but yes i do have the original 907ie shock that carl gave me when i bought his 907 with the penske shock.
as carl said it is in superb shape ( i.e. 6000 miles of usage ) and only needs to be nitrogen recharged.
anyone interested in purchasing please contact me via pm and we can discuss.
thanks.
 Post subject: Fox Shocks
PostPosted: Thu Nov 16, 2006 1:11 am
I was told by my local bike shop that RaceTech took over/bought out Fox's streetbike shock line. I don't know if this is true but it never hurts to make a call. http://www.race-tech.com
 Post subject: Re: paso shock rebuild?
PostPosted: Thu Nov 16, 2006 10:25 am
PostPosted: Thu Nov 16, 2006 4:16 pm
I purchased a couple of these kits from this vendor earlier this year. If there are any questions about the individual pieces I can break one out and look at it for you.
The transaction was flawless. I would buy from them again.
- mark
PostPosted: Thu Nov 16, 2006 9:40 pm
shows shocks for all the Paso models:
I had them build a custom shock for my VFR years ago and they were great to work with.
PostPosted: Thu Nov 16, 2006 10:36 pm
PostPosted: Thu Nov 16, 2006 10:39 pm
