| Parts Interchange http://ducatipaso.org/forum/viewtopic.php?f=3&t=1508 |
| Author: | 90_907ie [ Thu Dec 14, 2006 5:13 pm ] |
| Post subject: | Parts Interchange |
| Author: | Duc750 [ Fri Dec 15, 2006 1:11 pm ] |
| Post subject: | |
| Author: | 90_907ie [ Fri Dec 15, 2006 3:13 pm ] |
| Post subject: | |
| Author: | persempre907 [ Fri Dec 15, 2006 5:03 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Fri Dec 15, 2006 8:46 pm ] |
| Post subject: | |
| Author: | persempre907 [ Fri Dec 15, 2006 9:16 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Fri Dec 15, 2006 9:32 pm ] |
| Post subject: | |
| Author: | wilbur [ Mon Dec 18, 2006 4:46 am ] |
| Post subject: | |
Another kick stand on Ebay if you still need one. |
| Author: | persempre907 [ Mon Dec 18, 2006 9:32 am ] |
| Post subject: | |
I'd buy it. No matter, the frames are the same, except for the front side (radiator and headlamp subframe) so you can fit it for sure. Ciao |
| Author: | Finnpaso [ Mon Dec 18, 2006 2:28 pm ] |
| Post subject: | |
Btw, those side stands are made from alumium, so if U know some aluminium welder, he can "reweld" it to suitable, like i did to mine for Conti pipes. It brake easily, if U try to bent it by own tools. ST series have steel side stand. :thumbup: |
| Author: | mikeakageoff [ Thu Jan 18, 2007 8:09 pm ] |
| Post subject: | |
From what's been said above, does that infer that early monster swinging arms fit 907's. Also is there anything else that fits ? cheers Mike |
| Author: | Duc750 [ Thu Jan 18, 2007 8:57 pm ] |
| Post subject: | |
Hi Mike Give Baines Racing a call - I think they may have a swingarm knocking around - whats happened to yours by the way ? could someone like Spondon repair or " re dress" it? |
| Author: | mikeakageoff [ Fri Jan 19, 2007 9:51 am ] |
| Post subject: | |
the chain went, locked round the back wheel and took great chunks out of the swinging arm, after it had smashed a few of the plastics on route. cheers Mike |
| Author: | persempre907 [ Sat Jan 20, 2007 9:22 am ] |
| Post subject: | |
I hope you are fine :thumbup: . Has the swingarm only dents or is it bent? If there are only dents you can fill up with the aluminium. You have also to do a metal casting and then you will take off the excess and will brush it. It will look as new :thumbup: :thumbup: :thumbup: Ciao |
