| Replacement CPU http://ducatipaso.org/forum/viewtopic.php?f=3&t=1572 |
Page 1 of 3 |
| Author: | Timbo [ Mon Jan 22, 2007 10:59 pm ] |
| Post subject: | Replacement CPU |
Hello to you all in cyber space.... Can anyone help Im after a replacement CPU P7 either new or second hand. The problem with my Duc ( so my mechanic tells me) seems to be fuel injection which is regulated from the CPU Does anyone have one? or can tell me where to buy one from. Cheers Timbo |
| Author: | ducwad [ Tue Jan 23, 2007 2:49 pm ] |
| Post subject: | |
I have no experience with these. I've just been keeping the link around. It seems to me, though, that this might help you as they have a P7/P8 product. |
| Author: | Timbo [ Tue Jan 23, 2007 10:11 pm ] |
Ducwad Many thanks,have been on the web page its $650 Autralian dollars which converts to £260.00p for a replacement CPU.Not that bad really but Ill keep looking............. If I cant find anything else Ill have to part with my hard earned cash(a small price to pay to keep my Duc on the road) Cheers :thumbup: Ride Safe Timbo |
| Author: | persempre907 [ Tue Jan 23, 2007 10:37 pm ] |
| Post subject: | |
Timbo, is your problem in the ECU or in the injectors? Ciao |
| Author: | keepsdad [ Tue Jan 23, 2007 11:03 pm ] |
| Post subject: | |
well, i tell you what. not a pleasant thought to have to purchase one but it is extremely reassuring to know that if you have to, you can purchase one. otherwise, i guess you just wind up with a paso paperweight. :thumbup: |
| Author: | ved [ Wed Jan 24, 2007 8:03 am ] |
| Post subject: | |
hi, ford had used the p8 in the sierra. but there are different generations. the car-version has no co2-screw, 4 power-amps and a different eprom. co2-srew is only a potentiometer and the eprom use a socket. the 2 mor amps shouldn´t care. may this info is useful for you. |
| Author: | Timbo [ Wed Jan 24, 2007 1:40 pm ] |
| Post subject: | CPU replacement |
Hello Thanks for replies guys.. Franceco the problem is with the CPU not injectors they re working, fine whats happening the petrol is not injected at the same time of the spark.This is causing a kick back on engine due to valves being open ??????. All timing,electrics, plugs etc are fine. The Eprom is also fine, fault believed to be within electrical circuit of CPU. I have found (via Ducati Owners Club GB) a company in England called Correction Injection who hopefully can help. Many thanks Stay safe Timbo |
| Author: | persempre907 [ Wed Jan 24, 2007 1:57 pm ] |
| Post subject: | |
This is a good thing. I think would be easy for an electronic expert fixing the ECU, considering also the eprom is working. It's a pity Antti (Finnpaso) is now cooking in the sun of the Red Sea. For sure, he could tell us something. No matter, I think the company will help you. If they will not be able, let us know. Someone of us has surely another ECU for spare part (I also have one). Ciao |
| Author: | persempre907 [ Wed Jan 24, 2007 10:37 pm ] |
| Post subject: | |
| Author: | Timbo [ Sat Jan 27, 2007 3:49 pm ] |
| Post subject: | CPU Replacement |
Francesco Thanks for repy,Ill keep watching them.There's also a 851/888 on ebay in UK valued at £131.00p.....its got about 3days left. Antti in a country that is sunny+ hot it doesnt bear thinking about!!!!! :confused: I dont think he's at his best unless the temp is 0 degrees or lower :funny: :funny: :funny: Ill let you know how I get on. Cheers :thumbup: Timbo |
| Author: | Rockwellman [ Mon Feb 05, 2007 11:02 pm ] |
| Post subject: | |
Hi I have a spare Merilli ecu from a 91 H Reg 906 if that's any use to you? I am looking for the integrated indicator lenses? Thanks Michael |
| Author: | Timbo [ Tue Feb 06, 2007 2:46 pm ] |
Hello Michael and welcome to our forum. :thumbup: Thanks for reply but as far as Im aware the 906 CPU is not compatible for the 907 something to do with injection side of things which is the very problem I have Ive just looked on e-bay and there 907 indicator lenses up for auction perhaps this might help you.... Many thanks again Ride safe Timbo :thumbup: |
| Author: | Finnpaso [ Thu Feb 08, 2007 3:23 pm ] |
| Post subject: | |
Sorry, Timbo, that i havent time for reading hole story, BUT if U need P7 ECU, i know, that they have that in offer just now in Ducati/Italy: Ordering number: 28610071A Centralina IAW 043 (07) 851 Superbike biposto 91/92. I think, just same ECU, as in 907, but with 851 Eprom, so propably this will fit also to 907IE by changing only Eprom, what is very simple job.... Btw, normal price seems to be 868€, but in offer 104,66€, so its not so bad investment for future to buy one for "spare parts"... |
| Author: | persempre907 [ Thu Feb 08, 2007 7:21 pm ] |
| Post subject: | |
Antti, do you think the ECU might be repaired by a good electrician? Ciao |
| Author: | Finnpaso [ Fri Feb 09, 2007 7:26 am ] |
| Post subject: | |
That P7 ECU have plenty of very small "surface mount" components, so need to have very small weldering tools and surely also magnifying glass with good light, so its not anymore "simple job" for normal "home electricians"... Btw, Have You guys maintained Your injectors ever???? They also need maintaining, cause there is also one small filter, what You cant change at home. Not so bad idea to maintain injectors every 40 000kms, or so. Its not so expensive in such carburetor/injection maintainer. I have done that one time and i was satisfied, what they did. :thumbup: |
| Page 1 of 3 | All times are UTC |
