ducatipaso.org :: View topic - MARZOCCHI M1R
ducatipaso.org
http://ducatipaso.org/forum/
MARZOCCHI M1R
http://ducatipaso.org/forum/viewtopic.php?f=3&t=1678
Page 1 of 2
Author:  Stingray230SX [ Fri Apr 06, 2007 2:19 am ]
Post subject:  MARZOCCHI M1R
Author:  Desmo_Demon [ Fri Apr 06, 2007 12:46 pm ]
I just replaced the seals and dust boots on my '87 Paso 750 Marzocchi M1R forks. They are still available through Ducati. I got the dust boots from http://www.proitalia.com and was fortunate enough to find a local shop that had some OEM Marzocchi seals that were also used on an 80's KTM dirtbike. Here are the measurements that I got from the original components on my Paso....
Seal (marked 41 - 55 - 10 - 10)
ID = 41mm
OD = 55mm
Thickness - 10mm
Dust boot/scraper (no markings)
ID = 41mm
OD = 60mm
Total height - 13~13.5mm
OD of lip for slider - 55mm
Height of lip for slider - 5mm
Thickness of section that rests on top of slider - 3mm
I hope this helps.
Author:  Stingray230SX [ Sat Apr 07, 2007 12:14 am ]
Author:  persempre907 [ Sat Apr 07, 2007 8:14 am ]
Author:  Finnpaso [ Sat Apr 07, 2007 1:14 pm ]
Author:  Stingray230SX [ Sat Apr 07, 2007 4:13 pm ]
Author:  Finnpaso [ Sat Apr 07, 2007 7:49 pm ]
Author:  Stingray230SX [ Sat Apr 07, 2007 8:35 pm ]
Author:  Finnpaso [ Sat Apr 07, 2007 9:03 pm ]
Author:  Finnpaso [ Sun Apr 08, 2007 9:16 am ]
Author:  Stingray230SX [ Mon Apr 09, 2007 3:27 pm ]
Post subject:  availability from ducati?
I was under the impression that these seals were unavailable from ducati any more???
i have no local,indeed no in state ducati dealers at all and will try to call BCM as they are always recommended on the ducati list.
however if that falls through i will go back to the marzocchi guys and hopefully come up with a set of seals/scrapers.
anybody know for sure what the status is?
doug
Author:  Desmo_Demon [ Mon Apr 09, 2007 4:55 pm ]
Post subject:  Re: availability from ducati?
Author:  Stingray230SX [ Mon Apr 09, 2007 7:09 pm ]
Author:  persempre907 [ Mon Apr 09, 2007 7:51 pm ]
Author:  Stingray230SX [ Mon Apr 09, 2007 10:47 pm ]
Page 1 of 2 All times are UTC
http://www.phpbb.com/
