| To FIM or not to FIM... http://ducatipaso.org/forum/viewtopic.php?f=3&t=1810 |
Page 1 of 2 |
| Author: | Cybermunster [ Tue Jun 19, 2007 12:27 am ] |
| Post subject: | To FIM or not to FIM... |
| Author: | persempre907 [ Tue Jun 19, 2007 12:29 pm ] |
| Post subject: | |
You can find all the info about the FIM chip in their website. http://www.fuelinmoto.com.au There is a specific chip for the 907. Here there are the results. Ciao |
| Author: | Finnpaso [ Wed Jun 20, 2007 3:29 pm ] |
| Post subject: | |
| Author: | Tamburinifan [ Sat Jun 23, 2007 8:33 am ] |
| Post subject: | |
Are that 907 chart accurate? Seems pretty low which also the one f 851 is: Gert |
| Author: | persempre907 [ Sat Jun 23, 2007 1:27 pm ] |
| Post subject: | |
Those charts show the HP at the rear wheel! Ciao |
| Author: | Tamburinifan [ Sat Jun 23, 2007 8:33 pm ] |
| Post subject: | |
| Author: | persempre907 [ Sun Jun 24, 2007 4:33 am ] |
| Post subject: | |
| Author: | Tamburinifan [ Mon Jun 25, 2007 9:41 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Tue Jun 26, 2007 4:24 am ] |
| Post subject: | |
Check that code from from ECU! Whats it???? I am quite sure, that U have P7 and U can use FIM EPROM normally in that P7, BUT IF U want to change mapping inside FIM eprom AND STORE THAT CHANGING to EPROM, then You need AMB. AMB keeps changes(made by FIM software with flat top!!!) inside ECU after You turn ignition key to OFF mode.... |
| Author: | Tamburinifan [ Tue Jun 26, 2007 10:36 am ] |
| Post subject: | |
| Author: | Finnpaso [ Tue Jun 26, 2007 12:18 pm ] |
| Post subject: | |
| Author: | Tamburinifan [ Tue Jun 26, 2007 2:01 pm ] |
| Post subject: | |
Gothenburg. |
| Author: | Finnpaso [ Tue Jun 26, 2007 6:09 pm ] |
| Post subject: | |
Ok! :thumbup: I have friends in Malmö :laugh: P7 have these marks in label: IAW 043 / 04 WU 43.07 / 20A_28 I have 2 x P7 ECUs and both have exact same label/marks :thumbup: |
| Author: | Tamburinifan [ Tue Jun 26, 2007 11:55 pm ] |
| Post subject: | |
| Author: | LudeDuc [ Fri Jun 29, 2007 11:21 pm ] |
| Post subject: | FIM Chips |
I put in the Ferracci stage 1 chip when I put on my Cobra F1 pipes on my 1991 Paso 907ie and there was a noticeable improvement in performance. Has been running great for two year. You can get the chips here: http://www.ferracci.com/store/cart.php? ... etail&p=98 |
