| 907IE rear wheel bearings ??? http://ducatipaso.org/forum/viewtopic.php?f=3&t=200 |
| Author: | Finnpaso [ Mon Feb 21, 2005 1:21 pm ] |
| Post subject: | 907IE rear wheel bearings ??? |
Hi ALL 907 owners! Does anybody know, what shall be SKF number for those bearings??? And what are dimensions??? I havent take my out yet(dont know, when i do it), but want to buy new ones for waiting that changing.... Finnpaso |
| Author: | ducinthebay [ Tue Mar 14, 2006 5:08 am ] |
| Post subject: | |
Hey Antti, I just went through all this on a set of 907 wheels. The SKF # is 62203-2RS-C3 Notice that there are two 2's in that part number. Not a typo! Special bearing, but still in production. C3 is looser bearings, and helpful to take up some side loading, but not necessary. 17mm id x 40mm od x 16mm wide. The dealer no longer stocks them, and will try to sell you a kit of parts to fit a more standard 6203 bearing, that is only 12mm wide. The kit of parts includes two 4mm spacers, and a new spacer tube. Total is about $200. Instead, go to a good bearing supply house and get 16mm wide bearing. About $30 each. Same wheels and bearing as 91-97 SS and Monster. Phil |
| Author: | Finnpaso [ Tue Mar 14, 2006 6:59 pm ] |
| Post subject: | |
| Author: | KillerB [ Wed Mar 15, 2006 8:53 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Thu Mar 16, 2006 10:52 am ] |
| Post subject: | |
I have changed also to front wheel SKF bearings, but cant remember numbers... If Someone desperently needs those numbers, surely then i try find that from one of my thousends of notes from garrage liberary |
