ducatipaso.org • View topic - 91', 92', or MAYBE 93' 907IE ?
It is currently Sat Apr 25, 2026 4:59 am
 Post subject: 91', 92', or MAYBE 93' 907IE ?
PostPosted: Sat Nov 10, 2007 7:54 pm
PostPosted: Thu Nov 15, 2007 6:06 pm
Rogero
1992 "Red" 907 I.E.
PostPosted: Thu Nov 15, 2007 6:31 pm
PostPosted: Fri Nov 16, 2007 12:38 am
PostPosted: Fri Nov 16, 2007 5:25 am
PostPosted: Fri Nov 16, 2007 8:47 am
 Post subject: Re: 91', 92', or MAYBE 93' 907IE ?
PostPosted: Sat Nov 17, 2007 10:03 am
In the early nineties ducati took what they had on the laying around as Antti says
so it´s quite normal to see -91 907:s with both black and gold brembos but as
Francesco says -91 , 300 mm diameter discs, - 92 320 mm. The silencers are also
different (most of the time) although you can see - 91:s both with black silencers
and the newer type with aluminium wrapping. The seat is also a little bit different
in seat height, I have both types of seats and the newer type is lower. My - 91
also has aluminium wrapped silencers, but black brembos. I believe the - 92 type also
have a lockable gas cap?? :mrgreen: :mrgreen:
PostPosted: Sat Nov 17, 2007 1:36 pm
well, that would help make the case for mine being a 91.
i do not have a locking gas cap.
interesting point, i didnt know any of the pasos had these.
:wink:
PostPosted: Sat Nov 17, 2007 1:41 pm
PostPosted: Tue Nov 20, 2007 5:48 pm
Judging the year by the type of gas cap is risky at best. I'm pretty sure the later cap will fit an earlier tank with no problems so it doesn't prove anything either way.
-Craig
PostPosted: Tue Nov 20, 2007 7:10 pm
Its very easy to loose key and change newer type of gas cap to older modell and also via versa. That is quite small thing compared to saddle/mufflers/rotors/calipers/ECU(P7/P8).
 Post subject: Re:
PostPosted: Tue Nov 20, 2007 8:59 pm
PostPosted: Wed Nov 21, 2007 1:51 am
and beautifully maintained it was.
still get lots of people ogling it unwilling to believe that it is now 16 years old ! :shock:
PostPosted: Wed Nov 21, 2007 9:26 pm
PostPosted: Thu Nov 22, 2007 1:07 pm
