| 907 hot starting http://ducatipaso.org/forum/viewtopic.php?f=3&t=205 |
| Author: | Ducati-nut [ Sun Feb 27, 2005 11:59 am ] |
| Post subject: | 907 hot starting |
My 1990 907IE starts from cold ok, with aabout 1/3 choke but from warm or hot it fires up and cuts out refusing to start again until cold. Has any one expeienced this problem or can point me in the wright direction? |
| Author: | Finnpaso [ Mon Mar 07, 2005 10:09 am ] |
| Post subject: | |
Hi "nut"! Have You checked Your valve clearances allready??? Thinking, what happen, when exhaust clearances are too tight.....Easy to check! Maybe start ok, when cold, but when engine warms, then Not anymore, cause no pressure in sylinder........ Finnpaso |
| Author: | Ducati-nut [ Fri Mar 25, 2005 7:07 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Tue Mar 29, 2005 10:07 am ] |
| Post subject: | |
Hi! I hope You remember also drive and accelerate very hardly, BEFORE You check You valve clearances! No need to check valve cl. if Your valves are very dirty! Many forget that very important point before valve check..... Engine must be as "clear" as possible before job ...still thinking, that there can be some problems to figure out.... Finnpaso Antti |
