| Swingarm Brake Bracket Pin http://ducatipaso.org/forum/viewtopic.php?f=3&t=2180 |
| Author: | Desmo_Demon [ Thu Dec 06, 2007 9:39 pm ] |
| Post subject: | Swingarm Brake Bracket Pin |
Anyone here have a picture and dimensions of the swingarm pin for the rear-brake, caliper bracket? On the parts list, it is #037740070. This is the pin that is bolted to the inside of the swingarm to prevent the caliper bracket from rotating. I picked up a used 907 swingarm needing some work and it is missing this piece. The pin is no longer available from Ducati, so I was wondering what it looks like and it's dimensions so I can make one. Thanks! Also, anyone have the left swingarm end cap that the axle adjustment bolt goes through (part #37310041A)? This is still available, but at $35 plus shipping, it is more than I spent on the complete swingarm. |
| Author: | Tamburinifan [ Thu Dec 06, 2007 11:42 pm ] |
| Post subject: | Re: Swingarm Brake Bracket Pin |
Isn`t that the same pin on the 93-99 Monster swing? Ought to be avaliable. |
| Author: | paso750 [ Fri Dec 07, 2007 10:24 am ] |
if it is the same as on a Monster swingarm, then it is the same as on an 888 also. btw I would have all the parts you need but as a set and only shipment would cost more than what they ask for that part in US. G. |
| Author: | paso750 [ Fri Dec 07, 2007 11:35 am ] |
is is noticeable I currently have time ? the bolt is a grade 8.8. G. |
| Author: | Desmo_Demon [ Fri Dec 07, 2007 1:11 pm ] |
| Author: | paso750 [ Fri Dec 07, 2007 1:33 pm ] |
the pictures and measurements are made from a spare 907ie swingarm I`m keeping for similar reasons as you do
| Author: | gail [ Fri Dec 07, 2007 10:29 pm ] |
| Post subject: | Re: Swingarm parts ....DESMO DEMON |
RE Rear caliper bracket , 907 , Check US ebay - RPM CYCLE PARTS.....$30.00. BUY NOW. Hope its OK, .......Marty |
| Author: | paso750 [ Sat Dec 08, 2007 11:31 am ] |
| Author: | Desmo_Demon [ Sun Dec 09, 2007 2:31 am ] |
| Author: | persempre907 [ Sun Dec 09, 2007 2:34 pm ] |
| Author: | Desmo_Demon [ Mon Dec 10, 2007 2:49 pm ] |
