ducatipaso.org • View topic - Fan thermo sensor/switch
It is currently Wed Nov 12, 2025 1:24 pm
 Post subject: Fan thermo sensor/switch
PostPosted: Tue May 04, 2021 12:21 am
Apparently my fan thermo switch is bad. Does anyone know of a replacement for the sensor/switch ? I've read that it's a common sensor/switch. But I am having a hard time finding one that is a correct fit. Of course I can always run a bypass switch but I'd rather use a workable thermo switch. Thank you!
 Post subject: Re: Fan thermo sensor/switch
PostPosted: Tue May 04, 2021 9:09 am
That thermo switch was used on the 906, 907ie, 851, 888 and 9176 and early 748 but is no longer available.
However the switch for the later 748 and the 996 is available. It is essentially the same switch but with a different connector. It would need the connector of the 907 loom changed to fit.
PostPosted: Thu May 06, 2021 4:48 pm
A lot of this type of part was also common on cars. Isn't there a site or posting of common parts that where also used on cars at the time? Maybe it's on that list.
PostPosted: Sun May 16, 2021 2:27 am
Thank you Derek! I did a search for the 916 temp switch and found an aftermarket switch a lot cheaper. I also picked up a "lower" temp switch and installed that one first. It has the same electrical terminals as the 907. Thought I'd give that a try first before cutting and splicing a electrical plug for the newer style.
PostPosted: Fri Sep 03, 2021 11:05 am
Can You put some link here about that 916 switch. I mean, that where You bought it and what was price?
Users browsing this forum: Google [Bot] and 2 guests
