| wire color code for left switch http://ducatipaso.org/forum/viewtopic.php?f=3&t=2197 |
| Author: | osapitacud [ Mon Dec 17, 2007 11:03 am ] |
| Post subject: | wire color code for left switch |
Hi all, I have acquired a universal switch to replace a damaged original on my 907. However after looking at the excellent 'Wiring_907_colour.jpg' file and looking inside my old original switch I notice that some of the wire colours are different. Does anyone know which color wires are used to do the following? Headlight main wire Low beam Park light Pass / highbeam I have figured out the turn signals and horn ok. Cheers, Graeme New Zealand. |
| Author: | jcslocum [ Thu Dec 20, 2007 10:38 pm ] |
| Post subject: | Re: wire color code for left switch |
I did this on my 900SS and it was quite a pain in the a$$. I ended up cutting the old switch plug off and soldering it to the new wiring after tracing every wire. |
| Author: | Shelboss [ Fri Dec 21, 2007 2:30 pm ] |
Horn - gray - #1 Lights feed - grn/blk - #2 Right dir - red - #3 Hi Beam - wht - #4 Prk feed - grn - #5 Turn feed - blk - #6 Lo Beam - blk - #7 Prk - yel - #8 Left dir - blue #9 Numbers go left to right across the keyed side of the connector, then across the middle row, then top row. Good luck, Art |
