| Paso 907ie key blanks http://ducatipaso.org/forum/viewtopic.php?f=3&t=2273 |
| Author: | hondast [ Sat Feb 02, 2008 4:49 pm ] |
| Post subject: | Paso 907ie key blanks |
Hi all, I have a 1992 Paso 907ie and currently only have 1 key for it. Does anyone know where I can get a blank to make another key? Wayne in VA |
| Author: | paso750 [ Sat Feb 02, 2008 5:03 pm ] |
| Post subject: | Re: Paso 907ie key blanks |
| Author: | persempre907 [ Sat Feb 02, 2008 6:33 pm ] |
http://cgi.ebay.com/Ducati-Motorcycle-K ... otohosting http://cgi.ebay.com/DUCATI-CAGIVA-Key-B ... dZViewItem http://cgi.ebay.com/SUITABLE-KEY-BLANKS ... otohosting You can also search for a "Zadi 10" key (or compatible). Ciao |
| Author: | Stingray230SX [ Mon Feb 04, 2008 4:53 pm ] |
i can second the "keys4classics" guys i also purchased keys from them for my 907 and they were perfect doug |
| Author: | Shelboss [ Wed Feb 06, 2008 1:57 am ] |
I would have Keys4Classics make the keys up for you rather than having blanks copied locally. They are steel blanks and most places won't even cut them. The ones that will can screw up the depth and will make them difficult to use in the seat. If you don't know you key code, send him a picture and pay the extra money to get it cut to factory codes. I wish I had
| Author: | Stingray230SX [ Wed Feb 06, 2008 1:33 pm ] |
i never could find a keycode for my bikes locks, however one of the local locksmiths did an excellent job for me and all 4 keys work in ignition/gascap/seat.YMMV :-) doug |
| Author: | Mc tool [ Wed Feb 27, 2008 10:58 pm ] |
Silca ( italy ) also do a blank # ZD10p for the paso tiz a short key with a black plastic cap cheers |
| Author: | Stingray230SX [ Thu Feb 28, 2008 12:38 am ] |
i have one oem key that came with my 907 and its a silca its just like the keys4classics except the head is a little softer rubber it has the number Z0 or ZD then right below that in slightly smaller type: 16RP i have never seen any silca keys(blanks) like it for sale doug |
| Author: | mrinflux [ Thu Mar 06, 2008 2:14 pm ] |
| Author: | qldman36 [ Thu Mar 06, 2008 2:39 pm ] |
[I, the '91 907ie uses a different key blank than model years '92 and '93.[/quote] At least the early '91s. They used the remaining stock of 906 locks. Keys 4 classics came up with that info and sent the right blanks with no return on the wrong ones. Good people to deal with. |
| Author: | mrinflux [ Thu Mar 06, 2008 3:56 pm ] |
| Author: | Stingray230SX [ Thu Mar 06, 2008 8:24 pm ] |
yea if you look on the pictures supplied by the keys4classic guy........there is a groove that is different on the two blanks listed for the 907 fitment.(one blank has this groove closer to the edge than the other,if i remember correctly,sorry this was about 4 years ago for me) i noticed this in the picture and could tell that one of them did not match up to mine and when my keys arrived they were indeed like my oem silca doug |
| Author: | nickapaso [ Sat May 03, 2008 4:08 am ] |
Yes, I would also recomend the keys4classics guys. The local locksmith made a copy for me, and he did mess up on the depth. It took watching an entire movie with a small set of files to correct it. After I started, I just wanted to see if I could. It turned out okay, they all work in all the locks, but it took a couple of hours to fix, instead of importing more keys from australia. |
