Similarities 907-750? http://ducatipaso.org/forum/viewtopic.php?f=3&t=2279 |
Page 1 of 2 |
Author: | Tamburinifan [ Thu Feb 07, 2008 2:50 pm ] |
Post subject: | Similarities 907-750? |
What parts are interchangeable between a 907 -91 and a 750 paso -90? |
Author: | persempre907 [ Thu Feb 07, 2008 6:05 pm ] |
Post subject: | Re: Similarities 907-750? |
Not too much stuff. The fairings and the tank are different. Perhaps the rear fairings can be fitted. The mirrors, the handle-bars (I don't know about the master cylinders, but the front levers are the same), the footrests and the brake and the gear pedal, the headlight and the taillight. I hope don't forget anything. Ciao |
Author: | Finnpaso [ Thu Feb 07, 2008 7:16 pm ] |
Side panels are same. Also hole rear light system and that "scoop" behind sadle are same.... "undertray"(under saddle) and rear mudguard are same. Mot so many other things.... If you think 750 for spare parts to Your 907, i wouldnt go that way... Not so much common things... ![]() |
Author: | persempre907 [ Thu Feb 07, 2008 9:36 pm ] |
Author: | paso750 [ Fri Feb 08, 2008 9:55 am ] |
rear side panels passenger grab handle swingarm linkage seat lower frame rails horn (starter relay ?) oil and airfilter ... |
Author: | persempre907 [ Fri Feb 08, 2008 6:17 pm ] |
The whole keys kit. Ciao |
Author: | paso750 [ Fri Feb 08, 2008 7:47 pm ] |
sure ? Doesn`t one ignition switch have spade and the other round pin connectors ? Don`t know about the 907ie but I´ve seen this difference on other Duc switches. G. |
Author: | Finnpaso [ Fri Feb 08, 2008 10:13 pm ] |
i mean rear side panels are same! I didnt mention main fairings.... Main fairings are totally different.... Here we call those panels under seat side panels..... sorry. |
Author: | Tamburinifan [ Sat Feb 09, 2008 9:22 pm ] |
OK, thx guys! |
Author: | persempre907 [ Sun Feb 10, 2008 9:05 am ] |
As Antti told, if you really mean looking for a spare bike, you could search a Paso 906. She's much more common parts with the 907: engine, fairings, dashboard... Ciao |
Author: | Tamburinifan [ Sun Feb 10, 2008 11:28 am ] |
Not looking f parts bike. Just thinking if I should save a lightly crashed & negelected Paso ![]() in the attic at a car shop. |
Author: | krakan [ Sun Feb 10, 2008 12:26 pm ] |
Hi Gert, was that a 750 or what that you looked at that car dealer?? ![]() you definetly should save it no matter what!!! too few are left anyway. ![]() Krakan 907 red |
Author: | Tamburinifan [ Sun Feb 10, 2008 3:10 pm ] |
Yep, 750. Feel I have to save it, can`t let it just be dumped. Too much work/money to get it decent, thinkin of maybe parting it out. |
Author: | Desmo_Demon [ Mon Feb 11, 2008 3:55 pm ] |
Do they both use the Marzocchi M1R forks? |
Author: | Finnpaso [ Mon Feb 11, 2008 4:10 pm ] |
Yes, they use, BUT different model M1R... ![]() |
Page 1 of 2 | All times are UTC |
