| K&N filter http://ducatipaso.org/forum/viewtopic.php?f=3&t=2299 |
Page 1 of 2 |
| Author: | persempre907 [ Thu Feb 21, 2008 7:59 pm ] |
| Post subject: | K&N filter |
What kind of K&N filter will fit on the 907IE? I tried to search on the forum but I wasn't able to find anything. I bought the DU 0900, which fits on the 750, but also on the 851/888/900SS etc, but I found out it is higher than the stock kind, and I guess it doesn't fit well into the airbox. Can someone tell me something more about? Ciao |
| Author: | persempre907 [ Thu Feb 21, 2008 8:49 pm ] |
| Post subject: | Re: K&N filter |
Uuuuummmmhhhh, I'm doubting it's a DU 0900, because it seems to have an higher shape. It seems to me it has to be fitted in an airbox with a modified lid. Ciao |
| Author: | ducbertus [ Thu Feb 21, 2008 10:38 pm ] |
Francesco, I fitted one in mine as well. the fit was more difficult as the orginal filter. It seemed to me that the foam sides of the filter are thicker, because the latches were more difficult to close. A firm push did the job. I still have box of K&N filter. I'll look for you and let you know what is says. Ducbertus |
| Author: | Tamburinifan [ Fri Feb 22, 2008 12:50 am ] |
Same spare part no f all 90`s 2V Ducs. The higher one is "race", but fits. Have you tried it? |
| Author: | persempre907 [ Fri Feb 22, 2008 10:41 am ] |
| Author: | Finnpaso [ Sun Mar 02, 2008 11:51 am ] |
Both, normal and "race"(higher)would fit without any problem to normal Paso airbox... at least mine fitted, cause i have both.... Now i use that normal in my 907 and that "race" version in that bike, what i use "dayly", like its now in my ST2. I cant remember number codes just now....
| Author: | persempre907 [ Mon Mar 03, 2008 4:18 pm ] |
Do you think I'll need to adjust the carburation when I'll fit that filter? Ciao |
| Author: | paso750 [ Mon Mar 03, 2008 9:53 pm ] |
| Author: | Finnpaso [ Tue Mar 04, 2008 12:34 pm ] |
As he say, no need richer chip, but if change to more open exhaust, then need to adjust mixture(new chip). |
| Author: | persempre907 [ Tue Mar 04, 2008 11:39 pm ] |
| Author: | Tamburinifan [ Wed Mar 05, 2008 12:28 am ] |
| Author: | paso750 [ Wed Mar 05, 2008 2:48 pm ] |
| Author: | Debonair [ Thu Mar 06, 2008 12:48 am ] |
The airbox on my 750 has a section cut-out on it! I have #754693, can anybody tell me if this necessary or should I cover this cut-out back up (it has a K&N filter). |
| Author: | persempre907 [ Thu Mar 06, 2008 7:38 am ] |
It seems that the fitting of that filter in some airbox requires a modification to the lid. Specially, on the 851/888 and on the SS series, that filter fits only cutting the lid. I think that when the lid is cut out the engine should better "breathe". Ciao |
| Author: | paso750 [ Thu Mar 06, 2008 9:14 am ] |
guys be careful. This is the 907ie forum and Debonair has a 750. The airboxes are totally different. May ge a good thing to cut the airbox lid on a 907ie, but I wouldn`t do this on a 750. |
