| Pazzo levers http://ducatipaso.org/forum/viewtopic.php?f=3&t=2302 |
| Author: | Cybermunster [ Sat Feb 23, 2008 5:19 am ] |
| Post subject: | Pazzo levers |
I'm trying to get a set of adjustable Pazzo levers that will fit my '92 907, will the ones for a 900SS or 916 work. The seller does not have them specific for the 907 so wondering if I can use from other models. Thank you. |
| Author: | persempre907 [ Sat Feb 23, 2008 9:44 am ] |
| Post subject: | Re: Pazzo levers |
If you have the stock master cylinders on your 907, the 916 levers will not fit. You have to choose the early SS (until 1997) and Monster (until 2003) ones. They have the shape below, and fit both for the brake and the clutch master cylinders, while the 916 ones have the shape below. Later, the fitment will be very easy. Ciao |
| Author: | Cybermunster [ Sun Feb 24, 2008 4:53 am ] |
As usual sir, you are correct, tried a set from my brother's '91 900 SS and they fit perfectly (same exact levers). wooo hooo ..I'm ordering my Pazzo adjustables!! Many thanks!! |
| Author: | jcslocum [ Sun Feb 24, 2008 5:05 pm ] |
The Pazzo's are nice and the price is right! I have them on my 900SS. |
| Author: | Shelboss [ Fri Feb 29, 2008 2:40 am ] |
What about short vs. long Pazzo levers, any preferences? |
| Author: | Cybermunster [ Fri Feb 29, 2008 2:45 am ] |
My brother has the "shorties" on his 900SS, the brake is good but the clutch is a bit uncomfortable (too short for full 4 finger pulls). |
| Author: | jcslocum [ Wed Mar 05, 2008 10:51 pm ] |
I have the shorty levers. Seems to work fine for me. |
| Author: | Cybermunster [ Thu Mar 06, 2008 1:29 am ] |
Just installed them ...piece of cake! ..they look great and now I can adjust and compensate the clutch friction zone. Only thing I would do different would be to use a "shortie" lever for the brake and a "long" lever for the clutch, they do come in combined length sets. |
| Author: | Finnpaso [ Thu Mar 06, 2008 9:03 am ] |
Any link to "Pazzo" levers ? |
| Author: | jcslocum [ Thu Mar 06, 2008 5:05 pm ] |
GGGGGGoogle says: http://www.pazzoracing.com/ No Google in Finland? |
| Author: | persempre907 [ Fri Mar 07, 2008 7:40 am ] |
| Author: | Finnpaso [ Fri Mar 07, 2008 7:11 pm ] |
Frankie, this time Your are "little wrong": I start to be "too LAZY" to search all things by "kuukkeli", as we call Google.... and we surely have plenty of new very hig tecnology here, like very fast internet connection in near every house Minä kyllä ymmärrän, että yritätte "vittuilla" minulle silloin tällöin, mutta "paskat siitä" !!!! ![]() btw, do You guys let me to "pensioner", when i reach 2000 mails/advices to these sites ????? ...that i can concentrate ONLY for DRIVING my Ducatis! |
| Author: | Desmo_Demon [ Sat Mar 08, 2008 1:49 am ] |
I did some checking, and the levers should be the same between the Paso 750 and the 907, and......I also know that the levers from the '97-'00 ST2/ST4 (maybe up to '02) will fit the stock master cylinders, also. Here is a picture of the lever from a '98 ST2 (silver) on the master cylinder of a 1988 Paso 750. Here is a picture of the two levers side-by-side... I know the '00 ST2/4 levers are the same as the '98, as I upgraded my master cylinders in '00 on my ST2, and the levers are interchangeable. I believe the ST bikes used the same levers until at least '02, but someone may want to check on that. |
| Author: | Cybermunster [ Mon Mar 10, 2008 3:44 pm ] |
http://cgi.ebay.com/ebaymotors/Pazzo-Ra ... 0031082839 http://www.pazzoracing.com/ |
