It is currently Sat Apr 25, 2026 1:40 am
 Post subject: Removing oil filter nightmare
PostPosted: Mon Mar 17, 2008 1:09 am
Just when I get to what I think is the easy job Im wrong.Trying to take off the over tightened oil filter from the previous owner I have exhausted all options.I tried a strap wrench,wide channel locks,a Ducati oil cap wrench(but by now the grip points are all buggered up)and last I drilled a hole and put a large screwdriver through and tried to crank it off but no good.Anyone got any suggestions??Thanks :( :( :banghead:
 Post subject: Re: Removing oil filter nightmare
PostPosted: Mon Mar 17, 2008 2:42 am
righty tighty, lefty loosey...?
might sound dumb but I've fallen for this with bolts and bits in difficult places...
PostPosted: Mon Mar 17, 2008 6:50 am
I have a chain wrench (there is a chain instead of a strap as in a strap wrench) that works bloody well. Also, a very large plumber's pipe wrench (I mean a large wrench, not a large plumber) might do the job.
PostPosted: Mon Mar 17, 2008 2:25 pm
As a last resort, I've heard of people ripping the exterior case off of the filter and then using a hammer and chisel to knock the base counter-clockwise to get it off..........as a last resort. ;)
I wish you luck with it.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Mon Mar 17, 2008 7:05 pm
Screwdriver through filter from good position and then turn it open...... This have fuction here(last opinion).... :mrgreen:
Normally very good filter opening tool can open such filter, what cant turn with hands..... (better opinion) :thumbup:
PostPosted: Tue Mar 18, 2008 10:04 pm
I use a "Facom" tool with a toothed metal band you can strap tight with a large knob.
this "killer"never let me down.
Ducbertus
PostPosted: Wed Mar 26, 2008 2:33 am
You could try a large hose clamp or muffler clamp and hammer on that to loosen.
