| Removing oil filter nightmare http://ducatipaso.org/forum/viewtopic.php?f=3&t=2341 |
| Author: | macwig [ Mon Mar 17, 2008 1:09 am ] |
| Post subject: | Removing oil filter nightmare |
Just when I get to what I think is the easy job Im wrong.Trying to take off the over tightened oil filter from the previous owner I have exhausted all options.I tried a strap wrench,wide channel locks,a Ducati oil cap wrench(but by now the grip points are all buggered up)and last I drilled a hole and put a large screwdriver through and tried to crank it off but no good.Anyone got any suggestions??Thanks
| Author: | Laddie907 [ Mon Mar 17, 2008 2:42 am ] |
| Post subject: | Re: Removing oil filter nightmare |
righty tighty, lefty loosey...? might sound dumb but I've fallen for this with bolts and bits in difficult places... |
| Author: | Skins [ Mon Mar 17, 2008 6:50 am ] |
I have a chain wrench (there is a chain instead of a strap as in a strap wrench) that works bloody well. Also, a very large plumber's pipe wrench (I mean a large wrench, not a large plumber) might do the job. |
| Author: | Desmo_Demon [ Mon Mar 17, 2008 2:25 pm ] |
As a last resort, I've heard of people ripping the exterior case off of the filter and then using a hammer and chisel to knock the base counter-clockwise to get it off..........as a last resort. ![]() I wish you luck with it. |
| Author: | Finnpaso [ Mon Mar 17, 2008 7:05 pm ] |
Screwdriver through filter from good position and then turn it open...... This have fuction here(last opinion).... Normally very good filter opening tool can open such filter, what cant turn with hands..... (better opinion) |
| Author: | ducbertus [ Tue Mar 18, 2008 10:04 pm ] |
I use a "Facom" tool with a toothed metal band you can strap tight with a large knob. this "killer"never let me down. Ducbertus |
| Author: | Shelboss [ Wed Mar 26, 2008 2:33 am ] |
You could try a large hose clamp or muffler clamp and hammer on that to loosen. |
