ducatipaso.org • View topic - fork seal blowout
It is currently Sat Apr 25, 2026 5:01 am
 Post subject: fork seal blowout
PostPosted: Mon Mar 03, 2008 3:32 pm
Greetings,
I decided to drag my 907 out of its winter sleep and fire it up for a ride but then discovered some fluid on the left side of the front wheel. Further inspection indicated a blown left side fork seal, the right side tube had a film of fork oil on it that was much heavier than it should be considering that I replaced both seals a little over two years ago. I also had the tubes stripped and a new hard chrome finish applied at that time to clean up some pitting.
A couple of months ago I rode the 907 a couple of miles to the nearest gas station to fill up the tank. It was a sunny but VERY cold day, during this brief ride I encountered a few bumps in the road that were a bit harsh on the suspension. I recall thinking that I hoped it didn't harm the seals but now I'm wondering if the seals just couldn't take that kind of abuse in such low temps.
Anway, I'm now looking at a sizeable (to me) job to do that I feel shouldn't be necessary given the relative newness of the new fork seals and sliders in installed.
Your thoughts?
Regards,
Randy
'02 BMW RT
'06 BMW K1200S
 Post subject: Re: fork seal blowout
PostPosted: Mon Mar 10, 2008 8:40 am
Hi there ,did it actually pop the seal out of the housing or lip/seal failure?.... .Marty
PostPosted: Mon Mar 10, 2008 3:00 pm
Regards,
Randy
'02 BMW RT
'06 BMW K1200S
PostPosted: Mon Mar 10, 2008 7:31 pm
i have the p/n's from marzochi if you dont have them
doug
1992 907ie #1473 Nero SOLD
PostPosted: Mon Mar 10, 2008 9:25 pm
Regards,
Randy
'02 BMW RT
'06 BMW K1200S
PostPosted: Mon Mar 10, 2008 11:58 pm
i hope you can find those from ducati......
doug
PostPosted: Tue Mar 11, 2008 8:56 pm
Hi Randy,
normally you won't blow out the seals. But!!
there a obviously two kinds of seals.
the originally are about 7 or 8 mm thick and fit including the steel ring to lock the upper sleeve.
If you mount new Ariette seals they are 10 mm thick and the snap will not get in to the groove. these seals is what i got from my Ducati dealer.
I overcame this problem by leaving out the steel plates whitch locks the sleeves.
It still very hard to get the snapring in place.
leaving the snapring out seemed a bad idea to me.
I'll have to find new sleeves, because their condition is pretty worn out.
Ducbertus
PostPosted: Thu Mar 13, 2008 5:33 pm
if i get a chance this evening, i will try to post a pic of the new seals and wipers i got from marzochi........
doug
PostPosted: Thu Mar 13, 2008 11:55 pm
Just bought seals here in Sweden.
If you can`t find any , PM me.
PostPosted: Mon Mar 17, 2008 2:59 am
Hey Guys!
Thanks for the feedback! I was able to source some new seals from my local dealer and will be installing them very soon. I hope this is the last time I have to replace the seals! :banghead:
Regards,
Randy
'02 BMW RT
'06 BMW K1200S
PostPosted: Tue Mar 25, 2008 12:25 am
Just some info for you to digest.
I was doing some winter work on my 907 and decided to replace my forks seals. I ordered the OEM seals from the local dealer and then they were back ordered. I started looking at the part numbers, so while I was waiting for the "correct ones" to come in I installed seals from a 900SS. They were the same outside diameter and the same inside diameter, plus they were in stock. When I got them and started to install them I noticed they were just a bit taller. With the "correct" seals, they press in and then there is small washer then the retaining ring, then the dust boot. Well I figured the 900ss would fit if I left off the washer/spacer and just use the retaining ring, where could they go, right? Anyway, they worked fine, no leaks, no runs, no errors. I received the "correct" ones in about 3 months so I decide to install them. Put them in and within two weeks they leaked. One side just a little, but the other side quite a bit. I have since replaced the "correct" ones with a new set of the 900ss spec seals and no leaks in 4 years! Go figure.
PostPosted: Tue Mar 25, 2008 7:12 pm
Regards,
Randy
'02 BMW RT
'06 BMW K1200S
