ducatipaso.org • View topic - Spare parts catalogue!
It is currently Mon Sep 29, 2025 7:52 am
 Post subject: Spare parts catalogue!
PostPosted: Wed Dec 05, 2007 5:42 am
For 907IE 1992 now avaliable as PDF at http://www.duc.nu/manuals . :D :cool: :thumbup:
OK quality.
 Post subject: Re: Spare parts catalogue!
PostPosted: Wed Dec 05, 2007 8:25 am
viewtopic.php?f=1&t=1551&start=0
here you can find it for free. (in really good quality :)
PostPosted: Wed Dec 05, 2007 12:37 pm
I never understood how to open those bat-files.
PostPosted: Wed Dec 05, 2007 1:14 pm
there are 5 files, just download them and then doubleclick the .bat file.
The file was too big to upload so I had to slice it. Doubleclicking the .bat file will reconstruct all files to the original pdf. Just retried it myself. Works fine.
However, the site is quite cheap :thumbup:
PostPosted: Thu Dec 06, 2007 2:01 am
OK, Gerhard.
Downloaded 1 file w MS.
MS asked: Want to save or open?
When I said open, a PDF opened w/o problems. :)
When I closed that & tried to open again, a DOSwindow opened. :(
So, I`m no PCwizard, please help me open this .bat-file.
Am I missing something simple? :oops:
PostPosted: Thu Dec 06, 2007 9:56 am
just click on one file, if the download window appears do not cick "open" but "download". Do this with every file of the parts manual.
When you have all files on your PC (in one directory of course ie your desktop) doubleclick the .bat file. That`s it. Out comes the pdf.
When you have the pdf you can delete the downloaded files on your PC.
PostPosted: Thu Dec 06, 2007 10:32 am
OK, thx!
PostPosted: Wed Jun 04, 2008 9:11 pm
I'm new to this site. I'm a Paso fan, I don't currently own one but I do work on them from time to time & I would really like to access the info that someone was kind enought to load into a BAT(?) file, bur I am having trouble doing it. Has anyone else gotten this to work? I have downloaded all the files into their own folder but from there I'm making no progress. I'm no a PC whiz so any remedial help would be appreciated muchly!!!
TIA
DeAnna
PostPosted: Thu Jun 05, 2008 1:10 am
the instructions work OK. I have the manual and it's good quality.
download all the files into one folder.
select (double-click) the .bat file
It look like nothing happens but a .pdf file is created in the same folder.
This is the manual.
You need adobe acrobat to read the file.
You can delete the other files when you're finished.
PostPosted: Thu Jun 05, 2008 8:09 am
PostPosted: Thu Jun 05, 2008 8:41 pm
That's what I was meaning to write.... All files are in the same folder as each other. I made a new folder to put them in with nothing else in it. I was hoping it would help, but it didn't. I'm still stuck.
DeAnna
PostPosted: Thu Jun 05, 2008 10:24 pm
Hi there mate this is how I did it and I have done this with Windows XP and Now with Vista.
Download each file individually
Then make a new Folder.
Put all four items into the new Folder
Click on the Batch Folder.
This will now unzip the files and you will have a new file created.
This is your manual name it as such if you haven't already
You can now delete the rest.
Click on the File and you will go to the Acrobat File click again and you will open and be able to read and print etc.
If you haven't got Adobe Acrobat you will need to instal the free version prior to this set up purpose.
Hope this helps.
PostPosted: Sun Jul 06, 2008 6:12 pm
Anyway I can get the manuals in a non .bat file format? I MAC does not like them.
