| sprocket/chain and clutch line question http://ducatipaso.org/forum/viewtopic.php?f=3&t=2630 |
| Author: | bill h [ Thu Jul 31, 2008 11:44 am ] |
| Post subject: | sprocket/chain and clutch line question |
i am planning to add a 42t rear sprocket and replace my chain. will i have to add a 110 link chain or will the stock 108 links work? does anyone still make a stainless steel clutch line for a 1993 907ie? thanks in advance bill 93 907ie 72 norton commando 71 triumph t100c 66 norton 650ss |
| Author: | paso750 [ Thu Jul 31, 2008 1:13 pm ] |
| Post subject: | Re: sprocket/chain and clutch line question |
GALFER makes them. You find them on ebay. But you can also take any other if the length and the angle of the fittings is correct. The line I`m using came from a big scooter. G. |
| Author: | LudeDuc [ Thu Jul 31, 2008 6:12 pm ] |
Not Sure about your chain issue; but paso750 is correct Galfer model "FK003D94CL" is made for the 907IE Clutchline, just replaced mine this spring. |
| Author: | bill h [ Sat Aug 02, 2008 12:38 pm ] |
thanks to all who replied! did a google search and came up with a vendor. i went for both the brake and clutch lines/ i'll have to see if i need a longer chain when the sprocket arrives. bill |
