are there any big bore kits left ...? http://ducatipaso.org/forum/viewtopic.php?f=3&t=2706 |
Page 1 of 4 |
Author: | rosstb [ Wed Sep 03, 2008 12:45 pm ] |
Post subject: | are there any big bore kits left ...? |
Hi My 1992 907ie twisted a conrod into oblivian, taking out the barrel/sleeve, piston and a valve. It came as a surprise to discover the bike had a 94mm big bore kit in it - nobody had fessed up to this at the time of sale. I'm in OZ and we (the mechanic and I) haven't been able to source a kit here or from Ducati. If anyone out there knows of some reprobate hoarding a big bore kit in a shed somewhere, please tell me. I love the bike and want to get it back on its glorious (steroid induced) song. Regards to the fraternity Ross |
Author: | Tamburinifan [ Wed Sep 03, 2008 1:55 pm ] |
Post subject: | Re: are there any big bore kits left ...? |
Fast byFeacci has one, I think. Seen it ebay occasionally. Veeery expensive..... Haven`t checked the ST2 cylinders but ST2 heads fit on 907 cyls (I have it) so I guess cyls also fit. |
Author: | redpaso [ Wed Sep 03, 2008 11:01 pm ] |
Have you checked with Gowanlochs in Sydney? Good to have another Aussie on here, where abouts are you? |
Author: | ducbertus [ Thu Sep 04, 2008 8:56 pm ] |
Hi Ross, you may try http://www.Pistalracing.it, they produce a lot of pistons and cilinders for Ducati. Also Wössner in Germany is a possibility. (http://www.woesner-kolben.de) on the website of Silent Hektik I saw they can resleeve your cilinder. They promise a lot, and probably you have to pay a lot. Resleeving depends on the damage done to your cilinder/piston. Conrods?->Carillo or Crower both US suppliers goodluck Ducbertus |
Author: | LudeDuc [ Fri Sep 05, 2008 7:57 pm ] |
There has been one listed on ebay in the US for quit some time. Ducati 907ie. Big Bore 944 Cylinder & Piston Kit!! Item number: 110202747995 |
Author: | rosstb [ Fri Sep 05, 2008 10:38 pm ] |
Hello all, Many thanks for your suggestions. So far, I've had positive responses from Fast by Ferraci in the USA, Kaemna in Germany (http://www.ducati-kaemna.com) and am waiting to see if Ian Gowanloch (OZ) has something hiding in the shed on his farm. I'm yet to check out EBAY USA, Wossner or Pistalracing but will do so soon.... None of them will be cheap but it will still cost less to re-kit than to take the bike back to standard specs which has been roughly quoted as $5,000 to 6,000 Aust. So getting practical help has been just fantastic for me. The only irritation is that I had planned to ride the bike to the MotoGP at Phillip Is but it wont be ready in time. Redpaso - I'm in Canberra. Good to know I'm not the only tragic around here on a fully faired Duke. Regards to the fraternity Ross |
Author: | Shelboss [ Sat Sep 06, 2008 1:56 am ] |
The big bore kit on ebay is Fast by Ferracci as seller. It is going for $1450 US. Seems like 11.1 compression is high for the street, too bad they don't do stock compression. |
Author: | paso750 [ Sat Sep 06, 2008 8:36 am ] |
Stein-Dinse is listing it for € 1213,75 (#400006005) or http://shop.italo-shop-neuss.de/product ... r-900.html both expensive compared to Ferracci. G. |
Author: | Finnpaso [ Sat Sep 06, 2008 4:37 pm ] |
Such kits near doubble bikes price !!!!!! hahahahahaha...... ![]() |
Author: | jcslocum [ Sat Sep 06, 2008 4:55 pm ] |
If all you need is pistons, they are readily avaialable in 944 bore. Cylinders can be replated. ST2 will bolt on. The ferracci kit is a rip off! |
Author: | persempre907 [ Sun Sep 07, 2008 8:57 am ] |
Author: | Finnpaso [ Sun Sep 07, 2008 10:05 am ] |
I dont know Staine Dinse kits, but 900SS big bore kits DONT fit to water cooleed engines. I played with this big bore kit idea many years ago, but then i realized, that most of kits are for air cooleed engines, not fot water cooleed, BUT if shop promise, that they kit fits to water engine, then it MUST fit! ![]() |
Author: | jcslocum [ Sun Sep 07, 2008 3:31 pm ] |
The pistons will fit but the air cooled 900ss cylinders don't have the water cooling jackets. It's VERY easy to have the stock cylinders bored and replated. I did this to my Multi this past winter. It cost $321 for the overbore and Nicasil replating. ST2's are already 944 so that's an easy change. |
Author: | persempre907 [ Sun Sep 07, 2008 4:24 pm ] |
Author: | Finnpaso [ Sun Sep 07, 2008 5:27 pm ] |
...and RPM counter modification... ![]() Btw, does anybody know, does 907 and early(97-99) ST2 have same con rods and crank shaft system? i mean now, that if put ST2 sylinders and pistons, does it need to put also better con rods and crank ???? |
Page 1 of 4 | All times are UTC |
