It is currently Fri Apr 24, 2026 2:52 pm
Page 1 of 1
[ 4 posts ] |
| Author |
Message |
osapitacud
Post subject: Left switch connector plugs Posted: Wed Sep 24, 2008 10:38 am |
Joined: Mon Mar 05, 2007 12:00 am Posts: 18 Location: New Zealand
Hi all,
I'm looking to replace the 9 pin wiring connectors (male/female) used for the left switch.
Does anyone know if these connectors are obtainable? They may be a standard connector or are they Ducati specific?
I know I can get cheap connectors to do the job but I am hoping to keep it original should I need to replace the switch again.
Cheers, osapitacud
| Top |
englishstiv
Post subject: Re: Left switch connector plugs Posted: Wed Sep 24, 2008 10:35 pm |
| paso grand pooh-bah |
Joined: Wed Apr 09, 2008 9:57 pm Posts: 1097 Location: Manchester, England.
Personally I would replace the connector with the best quality replacemant you can find and buy another if you think you will have to replace it in the future, I am about to change all of mine as I have found that the pins seem to corrode and lose their connection far too easily. I have had a real problem with the tank connector especially.
If you wish to keep some degree of conformity then upgrade with a modern ducati replacement use the shell and body and wire it accordingly.
_________________ DUCATI 907ie STIMSON SCORCHER 3 WHEELER CZ 175 Sport.
| Top |
osapitacud
Post subject: Re: Left switch connector plugs Posted: Fri Sep 26, 2008 10:41 am |
I can easily upgrade the plugs but thought that if original plugs were still around that would be the best option.
| Top |
ducbertus
Post subject: Re: Left switch connector plugs Posted: Fri Sep 26, 2008 9:48 pm |
Joined: Sun Jan 07, 2007 12:00 am Posts: 531 Location: holland
hi osapitacud,
As these connectors have an rather open structure I put a lot of petroleum jelly into them, which make lasting much longer. I'm not sure you can get 9-pins sealed connectors. But maybe you can split it a 5-pole and a 4-pole sealed connector. not the most pretty solution, but effective. I started to replace existing connectors with sealed ones to improve reliability. Works well.
ducbertus
| Top |
Page 1 of 1
[ 4 posts ] |
Who is online |
Users browsing this forum: No registered users and 2 guests |
