| Left switch connector plugs http://ducatipaso.org/forum/viewtopic.php?f=3&t=2747 |
| Author: | osapitacud [ Wed Sep 24, 2008 10:38 am ] |
| Post subject: | Left switch connector plugs |
Hi all, I'm looking to replace the 9 pin wiring connectors (male/female) used for the left switch. Does anyone know if these connectors are obtainable? They may be a standard connector or are they Ducati specific? I know I can get cheap connectors to do the job but I am hoping to keep it original should I need to replace the switch again. Cheers, osapitacud |
| Author: | englishstiv [ Wed Sep 24, 2008 10:35 pm ] |
| Post subject: | Re: Left switch connector plugs |
Personally I would replace the connector with the best quality replacemant you can find and buy another if you think you will have to replace it in the future, I am about to change all of mine as I have found that the pins seem to corrode and lose their connection far too easily. I have had a real problem with the tank connector especially. If you wish to keep some degree of conformity then upgrade with a modern ducati replacement use the shell and body and wire it accordingly. |
| Author: | osapitacud [ Fri Sep 26, 2008 10:41 am ] |
I can easily upgrade the plugs but thought that if original plugs were still around that would be the best option. |
| Author: | ducbertus [ Fri Sep 26, 2008 9:48 pm ] |
hi osapitacud, As these connectors have an rather open structure I put a lot of petroleum jelly into them, which make lasting much longer. I'm not sure you can get 9-pins sealed connectors. But maybe you can split it a 5-pole and a 4-pole sealed connector. not the most pretty solution, but effective. I started to replace existing connectors with sealed ones to improve reliability. Works well. ducbertus |
