| Battery question http://ducatipaso.org/forum/viewtopic.php?f=3&t=2775 |
| Author: | Kurt [ Thu Oct 02, 2008 1:37 pm ] |
| Post subject: | Battery question |
OK, next question on my new 907. This bike is very clean, with a couple of notable exceptions. One has to do with the battery that came in it (but I am replacing with an Odyssey PC535 after reading this forum). Anyway, the battery had corrosion on the negative terminal, and when I took it out to charge it, noticed that it had a pretty short breather tube (tube on same side as neg terminal). Once I had the bike on the lift, I found that the breather had been breathing heavily on the lower part of the shock which was covered in battery goo, not a pretty sight. The plastic adjusting knob at the bottom of the shock is 40% corroded away and won't rotate. Oh, well, *sigh of resignation* I should go for a different shock anyway. So my question is, does this sound like there are any implications for the charging system? I'm going to find and clean all the grounds as advised in another thread, and will check the charge rates once I get it going. Thanks again, that's it for now, more later, no doubt! HaHa |
| Author: | andrew_b [ Thu Oct 02, 2008 5:36 pm ] |
| Post subject: | Re: Battery question |
Ouch, too bad about the shock! It's probably not the (on board) charging system that is at fault - if anything the 350W alternator is under-rated and tends to undercharge. More likely is that because of the undercharging, like most of us, the previous owner left the bike on a trickle-charger and perhaps it wasn't well suited to the battery. The other thing is that when you get home from a ride it doesn't hurt to pull the seat off to let the heat from the donk dissipate - it gets pretty cosy under all that plastic without any air movement. Personally I would definitely lengthen the tube also! Cheers Andrew |
| Author: | Kurt [ Thu Oct 02, 2008 9:18 pm ] |
Hi, Andrew, Thanks for the tips! Now that I recall, somewhere along the line, the previous owner mentioned using a battery tender of some kind. Judging by the amount of glop on the shock -- and a closer look today revealed that the spring has been notched, by battery acid no doubt -- I'd say he kept the battery on a low simmer, and maybe the owner before that, too. So the "old" battery is now a shop battery, and I am installing the Odyssey sealed battery -- no tube at all. Got the Odyssey from Battery Mart in Virginia, less that 48 hours after ordering on line, standard ground shipping, good service. Just installed the new air filter element and NGK plugs as recommended, put tank back on. Next, oil & filter change, ride a bit, decide what to do about the shock. More news as it happens ... |
| Author: | Laddie907 [ Thu Oct 02, 2008 11:14 pm ] |
bummer about the shockie. suggest you read the blurb from the manufacturer: http://www.odysseybatteries.com/odyssey101.htm#cca you must avoid trickle chargers with this style of battery - they need a 6 Amp charge (minimum). I'd also query the manufacturer about how "hot" it is necessary to protect from before the metal jacket is required. It gets hot in there next to the rear header... it will be interesting to see how the trickle discharge to the clock is handled by the battery. I find with a standard lead-acid battery it drops from 12.7V to (say) 11.6V in a few weeks. My guess is the Odyssey will handle it better... |
| Author: | Kurt [ Fri Oct 03, 2008 1:19 pm ] |
Many thanks, Laddie907. Charging info noted! I phoned the distributor Batterymart, spoke to Stan in customer service, who told me that the PC535 does not come in full metal jacket, and he noted the operating temp up to 140F/60C. Looks like there's and inch or more of space between the top of the battery and the bottom of the Corbin seat, allowing for some airflow. How about ventilating the battery box, like boring holes in the sides and rear to help hot air escape? Anybody done that? Any suggestions welcome |
| Author: | Shelboss [ Fri Oct 10, 2008 3:19 pm ] |
I have posted about charging in the past, I use a float charger on all my batteries unless they are severly drained. The float charger is 1.5 amps, but turns off when the battery is fully charged and turnes back on when the clock drains it below a certain level again. I also had an overcharging problem that would cause acid to spill. An AGM battery does not have this problem, it has no spill tube and no fillers. You may want to check your charging voltage at highway speeds, I think over 14 volts is too high. May want to think about another type voltage regulator if that is the case. |
| Author: | Kurt [ Fri Oct 10, 2008 9:04 pm ] |
| Author: | Finnpaso [ Sat Oct 11, 2008 3:08 pm ] |
Your voltages seems to be ok. Its very good idea to hook somekind GOOD voltmeter to Ducati and see, what will be voltages in higher rpm also, what is not so simple to check in home...
