ducatipaso.org • View topic - Rear Sprocket
It is currently Wed Oct 01, 2025 3:44 am
 Post subject: Rear Sprocket
PostPosted: Wed Oct 22, 2008 10:41 pm
Will a 750/906 rear sprocket fit on the wheel of a 907. Is it a different size/width etc? I know the wheels are different so are the hubs and the carrier for the sprocket?
Tried the search in the General Forum without any joy.
 Post subject: Re: Rear Sprocket
PostPosted: Fri Oct 24, 2008 7:25 pm
750 and 906 have same sprocket system, but 907 have totally anotherkind (like Monsters, etc have), so 750/906 rear sprockets DONT FIT TO 907 at all.... its easier to find right rear sprockets to 907, than to 750/906... Monsters "range" is very wide, so U have to choose from them right to Your 907..... :thumbup:
PostPosted: Fri Oct 24, 2008 10:59 pm
Thank you Antti :thumbup:
PostPosted: Sun Oct 26, 2008 4:49 am
...and for the front sprocket?
If I well remember the 907 front sprocket has some "offset" so is quite tricky to find.
PostPosted: Sun Oct 26, 2008 10:54 am
My opinion is, that ONLY original Ducati OEM 15 teeth sprocket fits 100% with right offset.... It can be also, that some of those big USA Ducati dealers, like Ferracchi have some own sprocket solutuin to front. Anyway its very easy to change rear sprockets (from Monster range, where range is very wide for rear). Some 900 Monster have very close same offset, as 907 have in front, was it some 2001, or so.. remembering now only!
PostPosted: Tue Oct 28, 2008 3:25 pm
PostPosted: Tue Oct 28, 2008 5:21 pm
PostPosted: Tue Oct 28, 2008 8:06 pm
I can only confirm, that original 15 sprockerts are still available, cause i get some from Italy some monthes ago. They are OEM parts.
