New RPM sensor needed http://ducatipaso.org/forum/viewtopic.php?f=3&t=2938 |
Author: | Daniel Gehrs [ Tue Dec 02, 2008 9:35 pm ] |
Post subject: | New RPM sensor needed |
My 1991 907IE is in need of a new RPM sensor which is referred to in the Parts Book as a "Proximity Switch", part #55240051A. I would like to buy a new one if possible and would appreciate any leads for dealers, etc. that might have one. I'm told that this part may also have been used on the 851 or other model of this era so it may not be totally unique to the 907. I would also consider buying a serviceable used one if need be. Replies can be sent to me directly at dan@dgwines.com. Thanks and Happy Holidays. |
Author: | Tamburinifan [ Tue Dec 02, 2008 9:48 pm ] |
Post subject: | Re: New RPM sensor needed |
Maybe one from the models w same flywheel & similar ECU works, 851/888, 916 Bip/SPS etc? Worth checking. Could work: http://www.gothamcycles.com/servlet/the ... ors/Detail |
Author: | Laddie907 [ Wed Dec 03, 2008 12:59 am ] |
these prox switches are very common on any Weber Marelli P7 / P8 EFI ignition system ...and similar on many others, too. the 851 is same for sure; also cagiva elefant common European auto Alternatives / part no.s Facet 9.0001 HC Cargo 150330 Hella 6PU009163171 Lucas SEB144 Marelli SEN8E 64820084 Meat-Doria 87005 OEM / Wholesale Alfa Romeo 60512971 60572239 Bresch SEN8E Fiat 5944390 7604582 Intermotor 18750 Webcon WSS001 WSS073 hope this helps... all details stolen from http://www.endless-horizons.net/efi/efi.htm |
Author: | Daniel Gehrs [ Wed Dec 03, 2008 11:52 pm ] |
Thankyou both for your helpful tips and encouragement. I will check out the leads that were provided soon and get my bike back on the road where it belongs. |
Author: | persempre907 [ Sat Dec 06, 2008 2:28 am ] |
Where are you? Any good shop of Italian cars spare parts can supply it. Ciao |
