It is currently Tue Sep 30, 2025 7:56 am
[ 4 posts ] |
Author |
germantrader10
Post subject: No Spark Posted: Mon Jan 19, 2009 6:39 pm |
What do i do Battery is good and new Fuel is good pump primes?????
Top |
Post subject: Re: No Spark Posted: Mon Jan 19, 2009 6:59 pm |
paso grand pooh-bah |
I thought you had no ECU
Top |
Laddie907
Post subject: Re: No Spark Posted: Tue Jan 20, 2009 4:03 pm |
Joined: Thu Nov 29, 2007 11:45 pm Posts: 174 Location: Australia
It might help to put in a bit more of a description of the problem...
like was the bike running and then just "stopped dead" or began misfiring or was it bought "not running" and you're trying to get it started...or maybe a friend borrowed it...
if you mean "no spark" suggest to: 1. check the kill switch is set to "RUN" 2. pull a plug and EARTH it to frame, then test... 3. check power to both coils 4. check power to both ignitors (be careful with earth) 5. check crank timing sensors
if you mean "won't start"? check the compression...
Top |
Post subject: Re: No Spark Posted: Tue Jan 20, 2009 6:17 pm |
also check each coils reisistance, I just had one crap out on me.............
Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 116 guests |
