| Separation issue http://ducatipaso.org/forum/viewtopic.php?f=3&t=3162 |
| Author: | Tamburinifan [ Mon Mar 23, 2009 12:49 am ] |
| Post subject: | Separation issue |
Sorry, bike related... Want to overhaul my clutch master reservoir and found the idle lever attached to it. How do I separate them? No screws visible or are they hidden? |
| Author: | Tamburinifan [ Tue Mar 24, 2009 12:14 am ] |
| Post subject: | Re: Separation issue |
Found out myself You loosen the reservoir, move the idle lever so it slips out of its seat and then you`ll see the screws f the idle assy to be removed from clutch reservoir. |
| Author: | Jaffa [ Tue Mar 24, 2009 1:28 am ] |
Well done Gert. The trick is getting it all back in place again. Good luck.
| Author: | Tamburinifan [ Tue Mar 24, 2009 11:47 am ] |
Yup, and first to get the reservior repair kit in first....
| Author: | Tamburinifan [ Wed Apr 08, 2009 5:21 pm ] |
A bit tricky and not so few words.(Also, reservoir had to be worked over abit to make the repair kit work. ) The idle lever cover loosens when positioned halfways over piston/ dust cover in reservoir. And of course reassembles in very same position, dust cover/piston must be compressed a bit. The wire mount hole towards el controls is the one to use, why there is another, who knows... All easier if wire loosened at TB`s. So now, .
| Author: | Finnpaso [ Wed Apr 08, 2009 5:35 pm ] |
Did You get repair kit ??? From where??? What price? Dont too much! I have done it sometimes and suffered about 4 days from it... Cant eat anything for 2 first days... then little by little same time quessing, does all come out very fastly, or after some minutes... |
| Author: | Tamburinifan [ Wed Apr 08, 2009 5:41 pm ] |
Kit from Bevelheaven, look f Brake rel parts-Brembo, 25,50 US$. Think Yoyodyne also has. I only drink Danish green Carlsberg, not a big bottle of Kosken in a sauna so I`m usually OK. But more work would be done without the beer, that`s for sure... |
