| cooling system pressure http://ducatipaso.org/forum/viewtopic.php?f=3&t=3198 |
| Author: | pasophist [ Fri Apr 10, 2009 7:14 am ] |
| Post subject: | cooling system pressure |
I think I have successfully plastic welded my split coolant overflow tank. I can't blow any air through leaks under water. Does anyone know what the pressure in the cooling system is that the tank should be able to withstand? Thanks, SMS |
| Author: | persempre907 [ Fri Apr 10, 2009 7:22 am ] |
| Post subject: | Re: cooling system pressure |
I wouldn't tell any crap, but the 907's cooling system wouldn't be under pressure. So, it's enough that it doesn't have any leak. Ciao |
| Author: | ducapaso [ Sun Apr 12, 2009 7:10 am ] |
the working pressure is marked on the water cap. That should be 1.1 or 0.9 (this means 110% or 90% over the normal atmospherical pressure) |
